Does Radarbox work with 978MHz UATs for General Aviation?
Started by drfrankencopter, March 11, 2008, 07:30:34 PM
drfrankencopter
Just curious if the Radarbox unit will decode 978 MHz UAT data from GA aircraft or if it only works with the 1090 MHz extended squitter?
I'm curious because I've been doing some testing with the Garmin GDL-90 ADS-B UAT, and I don't see my aircraft showing up on the Radarbox display
Kris
Sorry it only works with the 1090 MHz extended squitter.
The UAT system you mention only works in Northern America & Canada.
