Skyscan V1300 Desktop Scanner Antenna
Started by mcwito, November 07, 2010, 11:35:48 AM
mcwito
Hello all I'm new here.
I have a Skyscan V1300 Desktop Scanner Antenna, it's an indoor antenna I using for my Yaesu VR120-D scanner. It has a BNC male connector and I want to know if this antenna is better than default antenna provided by airnav and if it's compatible whit the radarbox (my antenna has a BNC male output connector).
Here descriptions:
# 4 Vertical elements covering; 50 - 107 MHz, 108 - 136MHz, 137 - 175 MHz, 176 - 525 MHz
# Total coverage 25 - 1300MHz
# 4 Horizontal Rubber Duck Elements
# 8 300mm Groundplane Elements
# Heavy Duty Magmount Base
# 4m RG58 50 Ohm coax cable with fitted BNC
# Overall Height 930mm or 3'.
Thank you all.
flightinair
Quote from: mcwito on November 07, 2010, 11:35:48 AM
Here descriptions:
Thank you all.
Hi.
It will be no good, the wee mag mount you will find a better job.
all the best.
mcwito
Quote from: flightinair on November 07, 2010, 12:10:58 PM
Here descriptions:
Thank you all.
Hi.
all the best.
I dont understand you, my english is not good at all, can you explain me?
Thank you.
ACW367
The small antenna that comes with the radarbox will be better.  It is dedicated to the 1090MHz frequency used by Mode-S.  Your Skyscan wideband antenna will actually have poorer results.
BadWolf
Hi, there are two issues with that equipment that I see, the antenna is designed to be used for a very wide range of frequencies 25-1300 Mhz so it is best generalized as an antenna that is for a wide range does not have very good sensitivity at any particular frequency. You would be better served by an antenna that has good sensitivity at about 1 Ghz where the Mode S equipment operates.
Also RG-58 cable is meant fir UHF and VHF ranges so has poor performance due to higher attanuation loss at the above mentioned 1 Ghz range.
mcwito
Use the default aerial.  It works very well.  Put it near a window as high as possible. Try different positions for best results.
The Skyscan does not work well with Radarbox.
mcwito
Ok thank you guys I appreciate your help.
Whit default antenna, how much radio can I get? 200 kilometers? 300?
Best regards.
mcwito
How can I know if I can get a good signal?? maybe tunning 1090mhz on my Yaesu VR-120D and see what happen?
