Started by orkney, November 10, 2010, 06:44:10 PM
Hi Brian,
Yes, 125-800B c/n 258240.
chewycanes
Network flight not populating
C078BA C-GTSR A332 AIR TRANSAT (from AF & GA)
Brian
chewycanes
Morning Alan
3B772F 089 E121 FRENCH AIRFORCE (from AF)
Brian
Morning Brian, thanks again.
chewycanes
Quick question on the one you just did. When i populated it did not have the small a/c field populated ie C121? Can you confirm this.
Brian
Brian, it is an E121 for the AI, if it didnt populate I presume it is that well known bug in action and will require to be populated manually.  Its OK in the d/b
chewycanes
chewycanes
A05644 N1201Y C172 ON TIME AVIATION (from GA)
Brian
Brian,
A06544 N1201Y C172 was according to the FAA, cancelled from the US register on 06/10/2008 as exported to  Jordan.
chewycanes
I think he got lost on his way or he's home sick and on his way back.
Brian
#1031
He has taken his time then.
Comments from the Mode-s forum re this aircraft.
Recently had the above which comes down to N1201Y which is no longer current,
however this was being used by C172 JY-NNN when it came to the UK therefore I
assume now that that was rereg`d G-NETT it is still miscoded.
Aircraft is Hurn based.
Just for you Chris, another new aircraft for South Africa noted approaching Skye on Planeplotter en-route Keflavik-Prestwick is 008A2A ZS-DVL Cessna 208B Grand Caravan c/n 208B2243, Heymans Kole Pty Ltd.
Hope you can cope with the excitement of another new one.
flygfantast
4AAF0A = SE-KXJ, SF34, Saab 340B, c/n 340B-189, NEX Time Jet
4AAAB8 = SE-JYX, S76, Sikorsky S-76C, c/n 760518, Norrlandsflyg
4AB4B6 = SE-MEV, DV20, Diamond DA20-C1 Eclipse, c/n C0561, Linköpings Flygklubb
Also not populating 4891A5
Niklas
Cable: Ecoflex-10 (10m+1m)
Many thanks Niklas,
4891A5 is thought to be SP-ENF B737-4C9 c/n 25429 /2215 of Enter Air which was delivered yesterday.  I am however still awaiting confirmation.
