Started by orkney, November 10, 2010, 06:44:10 PM
Brian,
45B9C1 = OY-NNA, Canadair CL-600-2B19 Challenger 850, c/n 8073, Jetair from mode-s forum
Chris11
ZS-SFF is using 00B010 which is not in sequence. I have picked it up.
Quote from: Runway 31 on March 12, 2011, 09:56:50 AM
Thanks Chris.
Re ZS-SFF above, have you ever picked it up using its correct hex of 00B020.
Chris11
Yes Chris we are aware it is using the miscode as it did yesterday, have you ever picked it up using its correct code/
Chris,
4C803F 5B-DCL A320-232, c/n 2334, Cyprus Airways
Chris11
Sorry - got itthe wrong way round. No it has never been detected using the correct code
Quote from: Runway 31 on March 12, 2011, 02:48:31 PM
Chris11
AA5CBB N767NF Boeing 767-383ER  24729/358 TNT
#1492
Thanks on both counts Chris.
N767NF Became EC-LKV last month with Gestair Cargo/TNT so looks like it is miscoding.
Chris11
#1493
Hi Alan
I am not sure if the ZS-SFF can be regarded as a miscode. The aircraft might have been allocated that code by the SA CAA. South Africa does not have enough codes to cover all the aircraft registrations and while the CAA seems to follow the standard list there are exceptions to cover military aircraft and ZU aircraft that do not have a code. I will see if I can get one of the SAA pilots to snag the code and see what the technicians come up with.
Chris11
#1495
Cheers Chris, I see what you are saying but given that you state there is a code shortage it doesnt then make sense not to use one which is allocated and leave it vacant.  You would think that if there was a code going spare it would be used.  I have however added 00B010 to the database to ensure this aircraft is included.
It makes you wonder why when this aircraft has been in service since 2004, the code was only noted as unidentified on here on Friday as the aircraft will probably be flying every day.
3985A2 = F-HBNC A320-214 c/n 4601
flygfantast
4AE2AB = SE-XUK, Glasair SH 2 RG, c/n 2025-1219, Private Owner
Niklas
Cable: Ecoflex-10 (10m+1m)
chewycanes
Morning Alan
391249 F-GESJ BE9L AERO STOCK (from GA)
Brian
