Started by orkney, November 10, 2010, 06:44:10 PM
Nothing on either of those Chris.
Chris11
EI-DDL A320-214 c/n 533 destined for Yes Airways
from the Mode S group
chewycanes
Afternoon Alan
506C23 S5-AAS A320 Adria Airways (from Modes forum)
A87645 N838CA DHC8 (FAA)
Brian
Hi Brian,
Both were added earlier today.
Thaks
Thanks Chris,
4CA91D EI-DDL
Chris11
4B9856 TC-FBV A320-214   4658 Freebird Airlines
4249C8 VQ-BJN B737-524 c/n 28911/2993 UTair
Thanks Chris
They have both been added as has 4BBC4C, TC-OBL, c/n 676, A320-232, Onur Air, courtesy John Hargreaves.
mikek
not populating:
C87F0A, NZ4204, P3, Lockheed P-3K2 Orion, New Zealand - Air Force, 5202
Mike
Chris11
7C4720 VH-OCF - can't find details.
Hi Chris,
VH-OCF should be 7C472D and is a Navajo Chieftain c/n 31-8353002 and belongs to Arena International Aviation.
Morning, here are unknowns7not populating ones from Fridays LOG:
3991E6 (France)
3C4B08 (Germany)
3D0712 D-EAXU RALL Morane-Saulnier MS-893A Rallye Commodore 180 Private 10935
3D0973 several times with DECCX flight ID. So 3D0973 could be a strange kind of miscode for D-ECCX(3D0A3B).
3D0DC8 D-EDLW H207 Brditschka HB-207R Alfa Private 207-059
3D108A (Germany / new airframe or D-EENA hex misuse)
3D12D5 D-EFJP B209    MBB    Bo-209 Monsun Private 138
3D185B D-EHLZ C182 Cessna T182T Skylane TC Private T18208030 (EX N3529M)
3D18EC D-EHRO P28A Piper PA-28-181 Cherokee Archer 2 Fliegerclub Straubing 28-7790546
3D1F65 D-EKDH DR40 Robin Apex DR-400/140 B Private 1644
3D1FF3 D-EKIT C172 Reims Aviation F172N Skyhawk Flugschule Ardex 1994
3D2944 D-ENWM SR20 Cirrus Design Corp SR-20 Private 1040
3D325D D-ERIB G3 Remos G-3 Mirage Private
3D3529 D-ESJP TRIN SOCATA TB-20 Trinidad Private 870 (with N699MS flight id, so it could be on transfer)
3D3911 D-ETWB C172 Cessna 172M Skyhawk Private 17264568
3D3C25 D-EVAJ RV8 Van's RV-8  Private (not populating)
3D3F44 D-EWFC Z43 Moravan Zlin Z-43 Private 0040/01
3D405C D-EWPW Z50 Moravan Zlin Z-50LS Private (quite old info resource)
3D4106 D-EWWK C182 Cessna T182T Turbo Skyline Private
3E3889 D-IMPL C310 Cessna T310R Private 310R1375 (A strange one, because this airframe has two entries at airframes.org one with D-IMPL and one with N685CP; The CN - is identical. Or is there something like dual citizenship for airframes ;-) )
3E5D62 D-KAOG DIMO DIAMOND HK-36TTC Super Dimona Luftsportverein Kreis Osterode e.V.
3E6857 D-KESD DIMO DIAMOND HK-36TTC Super Dimona Flugsportgruppe Elz e.V. 36556
3E795D D-KLDT SF25 Scheibe SF 25 C Luftsportverein Detmold e.V.
3EEA38 D-2465 AS24 Schleicher ASW-24 Luftsportverein Goch e.V.
3EFB2A D-6803 GLID Rolladen-Schneider LS4a Luftsportgruppe Menden e.V.
3F7DC5 (Germany)
3FEA3C D-MKYY ULAC Evektor-Aerotechnik EV 97 Eurostar Luftsportverein Ruhr-Lenne Iserlohn e.V.
3FEB58 D-MYAZ
3FEBD0 D-MEEG GOLF Tecnam P 96 Golf S 100 Private
3FEC44 D-MBSG FDCT Flight Design CT-SW Private
3FEE44 D-MAHJ G3 Remos G-3 Mirage Private
3FEE52 D-MFAR C42 Ikarus C 42 Bison Private (source: DULV)
3FEF3F D-MLAK    SAVG Zlin Aviation Savage Cub Private
3FEF90 D-MRMY WT9 Aerospool WT 9 Dynamic Private (source: DULV)
3FEFB3 D-MVWH GYRO AutoGyro MTOSport Private (Is in Database, but Data is not transferred to MYLOG ("BUG hint") )
3FEFD1 D-MIOS
3FEFFB D-MNCI GYRO AutoGyro Calidus 912 ULS Private
3FF01F D-MBVL C42 Ikarus C 42 Bison Private
3FF032 D-MBCM
444032 (Austria)
4844B0 (Netherlands)
484943 PH-1308 VENT Schempp-H. Ventus-2cT N.G.M. Oerlemans 44
4AB469 SE-MCI P28A Piper PA-28-181 Archer 3 De Sleutel BV, NL 2843443
4B194D (Switzerland)
4D4343 (Monaco)
That's all from Friday. I hope you won't get scared about this "little" batch of new airframes. By the way: Did you noticed, respectively did you process by Thursdays batch? (http://www.airnavsystems.com/forum/index.php?topic=5633.msg64775#msg64775)
Yes Ingo tahnks again got Thursdays unknowns, just havent found the time to reply.
3E5C44 D-KADG, Glaser Dirks DG-800A, c/n 8-2A2
3E6CAB D-KGIT  unknown
3FEA29 unknown
3FED6A I have as D-MKIW, Evektor EV-97 Eurostar c/n 2002-1501
A15746 would match to N186DE, not assigned by FAA
AE06E1 163553 Beech UC-12F c/n BU-01, US - Marines
How did this one got to the db?
AE050D A6-EDF A388 A380-861 Emirates or did my get db get corrupted.
Chris11
4CA91F EI-ERF B757-256 26254/905
