Started by orkney, November 10, 2010, 06:44:10 PM
0 Members and 6 Guests are viewing this topic.
Ingo,
AE050D isnt in the d/b and its unknown.  A6-EDF is correctly in the d/b as 8960E7 so you appear to have some sort of corruption.  What does your navdata hold?
Thanks Chris,
4CA19F EI-ERF B757-256, 26254/905, I-Fly
AE050D was in both databases. Don't know how this entries get into there. I have deleted them from both databases. Let's hope that this will be a one-time occurrence. If not it could be a more serious problem.
Hope so, as I stated earlier its not in the d/b and I checked my database explorer and its not their either.
flygfantast
SE-DIP i in the db as "WFU Stored (ex Scandinavian Airlines System)" but is in service again, still with Scandinavian Airlines System.
Niklas
Cable: Ecoflex-10 (10m+1m)
Hi Ingo,
Thanks again.  The sunshine and the holiday weekend brings them out like flies.
3991e6 comes out as F-HEPG unknown
3C4B08 comes out as D-ABXH which is now N35LX
I have 3D0DC8 D-EDLW H207 Brditschka as WFU, can you confirm it is now active/
3D108A D-EENA unknown
I have 3D911 D-ETWB as written off, has anither aircraft been registered with this registration
D-IMPL became N658CP in January so it is moscoding using its old hex
4844B0 comes out as P4-LVA which is now M-LVIA AS65
The unknown as still unknown
Errata:
3FEA3C D-MKYY populates as D-MKKY, which is wrong
Quote from: Runway 31 on April 23, 2011, 05:43:23 PM
Yes indeed. At about 9:00 to 11:00 am UTC it's like a kitchen full of roaches if someone turns on the light: Airfield empty, sky full.
chewycanes
Evening Alan
3E72EC Flight ID D-KISI No other data
Brian
mike L
Hi Alan  one mising to day  3E72EC with a callsign DKISI
thanks mike
About 3D0DC8 D-EDLW H207 Brditschka was flying around for about 2 hours on yesterday morning. Can't give you a visual confirmation. The one and thing I could tell, that I have the combination 3D0DC8 DEDLW in the LOG on two boxes.
About 3D3911 without any flight id. Just found the reg to the HEX via airframes. Tracked it twice: 1st 8:00am UTC and 2nd 1:30pm UTC.
about D-KISI: was a Grob G-109B until 2007(last photo documentation I could found).
YXUphoto
Got a hit from 0D05D5 today.  Unknown reg., but code should be for a Mexican registration.  Any info would be appreciated.
Morning, here are the unknowns from Saturday:
136274 (Russian Federation / flight id RA3626K)
3C4851 was D-ABBQ a B738 of Air Berlin, which was transferred to JeJu Air in Feb 2010
3C48D6 (Germany / Air Berlin flight id [BER3406])
3C64FE (Germany)
3D0DC8 (Tracked it again @ 3pm UTC)
3D0E6B D-EDSD DR40 Robin DR-400/180R Remorqueur Luftsportclub Wuppertal 1299
3D2050 D-EKMI P32R Piper Aircraft Inc PA-32R-301T Saratoga 2 Rundflüge Oberpfalz (Was spotted 24th of march 2011)
3D25D5 D-EMOR M20P Mooney M-20J 205 Private 24-3058
3D26BF D-EXMR E300 Extra EA-300 S Private
3D2953 D-ENXB P28A Piper PA-28-161 Cherokee Warrior II Private
3D3CF0 D-EVIE
3E63F7 D-KDBB SF25 Scheibe SF 25 C "Falke" Fliegerklub Gardelegen e.V.
3FEAF4 D-MZBH DAL4 WDFL Dallach D-4 Fascination Private 068
3FECCC (Germany)
3FEF32 D-MNFG ECHO Tecnam P92 ECHO 2000s Private (Source DULV)
3FEF80 D-MLAJ PIVI Pipistrel Virus Private
3FEF9C D-MSHH DAL4 Dallach D-4 Fascination Private
4008B6 (UK)
44CE79 (Belgium)
4785E7 (Norway)
48415B (Netherlands)
48AD0A (Poland)
4B16A1 was HB-IOV A320 of Belair Airlines, which is now with XA-MYR of InterJet
4B8421 (Turkey)
That's all from Saturday.
Brian, Mike, Ingo
D-KISI Grob G 109B c/n 6408
