Started by orkney, November 10, 2010, 06:44:10 PM
Evening! The good weather and the holidays are over, so the unknowns will be delivered in the evening again.
3840BA F-WWSV A388 Airbus Test registration various A380 airframes Airbus Industrie
3C48E0 (Germany)
3D1625 D-EGQF C172 Reims Aviation F172N Skyhawk Private F17201593
3E6C04 D-KGCI S10S Stemme S-10VT Private 14-003
3EBA32 (Germany)
3EDE2C D-KZCE
3F9CEA (Germany MIL / GAF*** flight id's)
3F9D98 (Germany)
3FA5F5 (Germany)
3FB481 (Germany MIL / probably a tactical code for TOR)
3FEB08 D-MCCT FDCT Flight Design CTsw Private (Again this combi / for info only)
3FECE4 D-MWBS
4840D0 was PH-BZH a B763 of KLM and is now with Ethiopian Airlines ET-AME( 04001B) / Miscode or new airframe with this hex.
88780A (Thailand) / could this Thai Airways first A380?
A57B2A (USA / not so easy one)
A7CEED (SP-AVE uses this old hex again. It seems, that this will settle down as a recurring misuse of hex address)
That's all from Tuesday!
Evening Ingo,
Its been glorious here all day as well and the aircraft are trailing so even better.
3C48E0 unknown
3EBA32 unknown
3EDE2C D-KZCE unknown
3FECE4 D-MWBS unknown
88780A unknown
A57B2A comes out as N452SR which in not allocted but the last holder of the registration was an SR22 exported to Poland
Chris11
4689A4 SX-BMD - According to airframes.org/FAA it has been  reregistered as N765TA - miscode or a new one?
Flight ID was Olympic Airlines
Hi Chris,
I have it as N765TA but being readied for Al-Naser Airlines as YI-AQS.  Skyliner shows it on delivery KEF-SAW today and is still N reg'd and will be changed on delivery.
flygfantast
478351 = LN-RNG, F50, Fokker 50, c/n 20184, SAS
Skyliner: "ferried 28apr11 NWI-OSL after storage".
Callsign used was SAS9193
Niklas
Cable: Ecoflex-10 (10m+1m)
chewycanes
Morning Alan
AAFC11 N807CA CL600 ? (from FAA)
AE498B 80-0037 V22 US Airforce (from Fighter Control)
4CA946 EI-IGT B737 Air Italy
4CA52F No data
Brian
Morning Brian,
AAFC11 N807CA Canadair CL-600-2B19 Regional Jet CRJ-100ER c/n 7346.  Skyliners shows ferried 28-29apr11 YYC-YFB-KEF-LJU, + 7482 N436CA
AE498B 80-0037 Boeing CV-22B Osprey, c/n D1018, US - Air Force
4CA946 EI-IGT, Boeing 737-73V, 32421/1357, Air Italy ex G-EZJZ
4CA52F comes out as EI-DUI which was a Grumman GA-7 Cougar c/n GA7-0114 which is now SE-MBO
mikek
Are you sure AE498B is 80-0037 and not 08-0037.
Don't think the V-22 was with the USAF in 1980!
Mike
#2124
Woops sorry mike copied and pasted from above, its however correct in the d/b you wil be pleased to know.
chewycanes
Hi Alan
Oops .....
Obviously i need to check my typing before posting...
The old fingers don't always match the brain.
Brian
flygfantast
4AB4C1 = SE-MFA, F27, Fokker F27 MK050, c/n 20820, Amapola Flyg
4780AB = LN-RDA, DH8D on ferry flight from ESKN, sold?
Niklas
Thanks Niklas,
I have SE-MFA as c/n 20118
No worries Brian, we get there in the end.
flygfantast
Quote from: Runway 31 on April 29, 2011, 05:59:47 PM
Thanks Niklas,
You're correct, looked at the wrong row, 20820
is the MTOW!
Niklas
