Started by orkney, November 10, 2010, 06:44:10 PM
Thanks Chris.
E48982 PR-VNA, Cessna 525B CitationJet CJ3, c/n 525B0337
Ingo,
Batch 1
3C6460 unknown
3D2227 comes out as D-ELEL unknown
My d/b shows that 3D42AF was cancelled as D-EXMT and is now D-EXRI
3EC1A0 comes out as D-KOHL unknown
Ingo, batch 2,
4006F8 G-UKHP B463, c/n E3123.  My d/b shows it has been in storrage and is due for delivery to Ghana for Starbow Airlines.
471EA3 unknown
484E01 was B200 PH-VMP but became N363EA in early April
48ADA4, 4A8138 and 4A8198 are unknown to me.
#2508
Errata:
3FEA32 D-MBRG populates as D0MBRG
EDIT:
3E1B30 D-IBMM missing Space between Cessna and 310Q.
Ingo,
Fridays batch
3C416C unknown
3C7269 D-ALSI unknown
3D29A1 D-EOAB, Piper PA-28RT-201 Arrow IV, c/n 28R-8218013
45C940 unknown
45D970 OY-VKP, A320 c/n 2183 became RP-C3227 with Airphil Express 3/2010
4A33839 was delivered through Prestwick yesterday YR-NAY, Hawker 900XP, c/n HA-0182
4CC267 TF-FIX B727-256 c/n 29311/940, Icelandair
88808C VN-A325 A321-231, c/n 4747 Vietnam Airlines on delivery
Corrections from your last post made as well,
flygfantast
Not populating:
4AB210 SE-LPP, C182, Cessna 182T, c/n 18282057, private owner
45F037 OY-9414, WT9, Aerospool WT9 Dynamic, c/n DY-367
Niklas
Cable: Ecoflex-10 (10m+1m)
flygfantast
48ADA4 SP-LNE
4A8138 SE-LEH, F50, Fokker 50, c/n 20108, Skyways
Niklas
flygfantast
chewycanes
#2513
Evening Alan
484C9C with callsign PH-YMA but no other data found.
Brian
Found this after i posted :-
8 Aug 2010 ... More: YesMan Aviation More: Israel IAI-1126 Galaxy ... N274JC (cn 034) To become PH-YMA. YesMan appears to be a new Dutch operator ...
Horsham Spotter
#2514
Good evening Alan.
Just spent the day a Shoreham (EGKA) in West Sussex by the sea.
I have logged in total 56 aircraft. Of these 25 were not in the database.
Info from picture's that I have taken and confirmation of these picture's
from AB website and GAS modes info.
The only info not included is the owner details. With GA aircraft I use PRIVATE
as owner.
G-CDDK, 404CFD, C172, CESSNA 172, 172-65258
N80533, AAF74D, C172, CESSNA F172, 0095
G-BTYT, 40352D, C152, CESSNA 152, 152-80455
G-DOME, 40428D, P28A, PIPER PA28-161, 28-42062
G-BIUY, 401F4D, P28A, 28-8190133
G-BTJL, 403408, PA38, PIPER PA-38-112, 38-79A0863
G-BZEC, 4042D1, C152, 152-84475
G-BHIN, 401E4D, C152, REIMS CESSNA F152, 1715
G-TEXN, 401E90, T6, T-6G TEXAN, 168-176
G-BPJU, 402D7B, P28A, 28-41032
G-TLET, 403029, P28A, 28-41259
G-BMCN, 402567, C152, REIMS CESSNA F152, 1471
G-BMUO, 402710, C152, A152-0788
G-BPHI, 402D22, PA38, 38-79A0002
G-HJSS, 401967, SV4, Stampe SV4C, 1101
G-BFRV, 401D36, C152, REIMS CESSNA FA152, 0345
G-EDVL, 403E15, P28R, PA-28R-200-2, 28R-7235245
G-BPJP, 402D55, P28A, 28-41015
G-WARZ, 403E56, P28A, 28-42025
G-BNEL, 4028CB, P28A, 28-7916314
G-BHPL, 401E79, BU31, CASA 1-131E SERIES 1000, 1058
G-AWGD, 401791,C172, CESSNA F172H, 0503
G-AMNN, 40261A, DH82, DH82A TIGER MOTH, 86457
G-WARY, 403E55, P28A, 28-42024
G-EKKL, 40413D, P28A, 28-8416087
That's the lot sorry about the upper case not shouting it was just quicker.
Hope of use Steve.
3.1nm miles south of EGKK westerly App & Dep.
YXUphoto
A83E84 showed up yesterday.  Comes out as N630J, which is a Jabiru J250-SP (an ultralight).  Reported altitude of 34,000ft....therefore must be a miscode.
ACW367
#2516
Quote from: Horsham Spotter on June 11, 2011, 08:36:24 PM
Good evening Alan.
as owner.
G-CDDK, 404CFD, C172, CESSNA 172, 172-65258........
Hope of use Steve.
Steve - When you say logged, I presume you mean in your notebook, rather than on your radarbox.  G-BTJL and G-TLET are in the DB.
The others that you mention are not.  However they also have not been detected on any networking Radarbox over the last 9 months and have not been included on any log ever uploaded to the Mode S Yahoo Group.
Therefore, unless you say you logged them on your Radarbox (in which case you are the first ever to do so), I think it is safe to say none of the others are Mode S equipped.
There are those who have sharply critisied us in the past in other fora who say by server-scrapes of the CAA & FAA etc websites and registers we could balloon our DB with 7-800K more codes. They would have us upload every single code allocated by those authorities regardless of the status of the aircraft (let alone the transponder it may be carrying).  In that way you would get added to your Navdata tens of thousands of non-Mode S equipped aircraft which are basically useless for our hobby.  Of those server-scraped records probably over 300K would never ever be mode S equipped and probably 10K would also be permanently grounded (hangar queens, partially dismantled fire trainers, unairworthy museum aircraft etc), so what is the point of that!!
All that does is increase disk space used by the Navdata, which on some machines could slow performance.  They would be choking the DB and changes would still have to be administered by us updaters for these near-useless codes. This could detract us small band of volunteers from doing the already large administrative task of administering the 100K+ valid mode S codes that are in the DB and picked up by Radarbox users worldwide.
Our method is to keep our DB to those valid Mode S equipped aircraft, which users worldwide are picking up on their boxes.  This makes our task of administering changes to those valid codes easier.  If those aircraft you saw based at Shoreham do ever get the Mode S box slotted onboard, they will immediately be picked up by many users across the south coast, and we will endeavour to add them into the DB as quickly as possible after their first Mode S flight.
Users are now only getting a handful of blanks a day in their MyLogs (in the ones and twos for new aircraft in the most case) and where positively tied up, they are quickly added to the DB when reported via the various fora.  So users can quickly get updates to their MyLogs as aircraft are tied-up.  I have picked up 11,000 different aircraft on my box since the start of this year alone, and of those I have one not tied-up blank (which I suspect may be spurious) and another eight (mostly German GA) where I don't have an owner.  With only 0.0001% of my MyLog not sorted, Our system must be working :)
Hope this helps
ACW367
#2517
Morning, due to the "hard" work of the past year and the so called summer weather it's only a short list from yesterday:
3C1641 was D-AXLC an A320-214 (CN 1564) with several operators. Don't know whether it's again this Airframe or a another/new one or if it's just back in business.
3D3634 D-ESTW was a Rockwell Commander 114 in 2000. Don't know whether it's still one or not.
3FEC91 D-MQCT FDCT Flight Design CT-SW LSV Hohenasperg (airframes / confirmed by visiting their website)
3FEEF0 D-MALJ MD3R GRYF Airplanes MD-3 Rider Private(Flyitalia bankrupt) (Picture from May this year on Flugzeugbilder.de)
451F0C LZ-LDG MD83 McDonnell Douglas MD-83 Bulgarian Air Charter 53149 (airframes)
471EA0 (Hungary / WZZ2JQ flight id / WZZ: Wizz Air) ferry/delivery flight I guess.
48B241 (Poland)
4CA6A2 (Ireland)
514023 (Georgia)
A4F2EA (USA / Address bound to N418LZ according to FAA-registry)
That's all from Saturday.
Chris11
3FEB14 D-MKKJ  B & F Technik Funk FK-12 Comet FK12 c/n12-077
4245F5 - Unknown
