Started by orkney, November 10, 2010, 06:44:10 PM
3FEED3 D-MAAO CH60 Zenair CH.601D Zodiac AeroClub Goeppingen-Salach eV (http://www.abpic.co.uk/photo/1153913/ & http://ultraleicht-sud.weebly.com/referenzen.html & Airframes)
flygfantast
Not populating:
503C3B (Lithuania)
4245F5
4A930D SE-DXM, Hawker Hunter F MK 58, c/n 41H697449, Swedish Air Force Historic Flight
Niklas
Cable: Ecoflex-10 (10m+1m)
#2522
Thanks Niklas,
48ADA4 SP-LNE unknown last one with that registration in my d/b is an IL-14
4A8138 SE-LEH is in the d/b already since 2010 so should populate
503C3B and 4245F5 both unknown at this time
YXU,
The Jabiru as you state is the correct user of A83E84 and unfortuntely I dont know whcih aircraft could be usig the wrong hex.
Thanks Brian,
484C9C N274JC was operated by YMA Inc and is showing as cancelled from the US register to Holland 08/06/2001 so looks like you are correct.
Many thanks
chewycanes
Morning Alan
4249F4 VQ-BML CR2J Owner ? (from modes forum)
Brian
flygfantast
Alan,
4245F5  VQ-BNG  B737-86J  c/n 37747/3120  NordStar Airlines
Courtesy of John H from mode-s forum
Niklas
#2528
3F345D D-OWML BALL BF Stuttgart NL-1000 Freiballonsport-Verein
Muenster und Muensterland e. V. (http://freiballonsport-verein-muenster.de/pages/live-verfolgung/langstrecken-gasfahrt.php)
3D12B1 D-EFIF P210 Cessna P210N Press. Centurion Private P21000440 (http://www.abpic.co.uk/search.php?q=D-EFIF&u=reg)
Chris11
3C0A46 D-ASXD Boeing 737-8AS 33562 SunExpress Deutschland
Ingo,
You have 3F345D down as the hex for D-OWML and D-ELYY.  I know 3F345D is the balloon so what is the correct hex for D-ELYY?
3C0A46 is already in the d/b
Thanks Steve,
You work is appreciated
Chris11
A50F13 N425K Type is populating as a BE9L - Should be P28R
Thanks Niklas,
I havent had time to go onto the mode-s forum yet been to busy with what is on here, many thanks to you all
