Started by orkney, November 10, 2010, 06:44:10 PM
John Hargreaves
505DD9 is OM-SYN Cessna C525B Citation. Dont have a c/n.
flygfantast
D-AHIN is again being used by Hamburg International and is not stored any longer.
Niklas
Cable: Ecoflex-10 (10m+1m)
John Hargreaves
Ex Hamburg A319-112s D-AHIN c/n 3853 and D-AHIO c/n 3872 are now with Air Berlin.
flygfantast
Quote from: John Hargreaves on January 22, 2011, 12:58:44 PM
Sorry my bad, you're right, looked at the wrong column!
Niklas
Hi Ingo,
3C7267 =D-ALSG UNKNOWN
A782DD N538UP entered shortly after take off
60085 - 4K-AZ80 A320-214 c/n 2991 Azerbaijan Airlines seen climbing over Romania earlier
3CCD4 = D-CFGE unknown
Two further HEX to investigate:
091A21 and 04C033
Ingo,
091A21 - hex not allocated to any country
04C033 - Kenya unknown
btclarke
D-ABKI is not a B722, but rather a
B737-86J/WL
Air Berlin (BER)
Mode S: 3C4969
BT
D-ABKI is in the d/b as you state not a B722.
Alan,
With regard to the query from BT on D-ABKI, I seem to remember it coming up in AN as a B737 of Air Berlin but the corresponding photo showed the the previous holder of the registration, a B722 of Lufthansa. This is perhaps what is causing the confusion.
BT
You will need to delete the photograph of the B722 from your own database and also Database Explorer and hopefully the system will replace with the current Air Berlin B737 photo when you next log the aircraft.
That may well be the case Ian.
Alan,
Just spotted this guy in the dark flying over at FL380. Mode S given is 780711 but not populating and can't find anything on Airframes or Libhomeradar.
Any Ideas ?
btclarke
#809
Erm, ok then.
But how does this happen?
Does the database not self-update when new entries are found?
