Started by orkney, November 10, 2010, 06:44:10 PM
Chris11
Not populating
E8404F HC-CIY Boeing757-2K2 c/n26635/608 Aerogal
BT, if all the columns of a AC entry are filled no look up in the central Database will be proceeded.
As far as I know there are two ways to force a auto re-population:
1st. Delete the complete record from the Database. Next time the AC's HEX address will be received the new -and then hopefully correct- Data will be added to your Navdatabase. The existing pictures of the B727 shall be overwritten.
2nd. Go to your picture folder and delete the pictures D-ABKI.bmp and if present D-ABKI,2.bmp. On next time the AC is received, the Software will look for the missing pictures and will detect the new AC Data and shall update your Database.
As far as I know a recurring check whether the AC Data is still correct or not, is unfortunately not part of the software at present time.
Hi, here some further not populating:
40649B G-CGSE E135 Embraer EMB-135BJ Legacy (600) GE Capital Corporation (GECC) 14500995
45ACCD from Denmark, but nothing more
On AC not populating from today morning:
42496D VQ-BFW A320 Airbus A-320-214 Ural Airlines 2327
Ian,
780711 B-3176, Embraer 190-100LR, c/n 19000406, Tianjin Airlines on its delivery flight.
#815
BT,
The database doesnt get over written by new data unless forced as detailed by Neroon79.  I would also caution that the existing pictures in your photo folder may also still be used so delete them.
Ingo.
40649B G-CGSE is in the d/b
54ACCD comes out as OY-KFM and is unknown
42496D UR-BFW  is in the d/b
btclarke
Quote from: Runway 31 on January 23, 2011, 09:17:48 AM
BT,
Ok, so I need to go and manually double check every record I have to eliminate erroneous data population by ANRB?
That just doesn't sound fun.
This hasnt come as a surprise for you has it, where have you been!!!
It isnt erroneous data population, the data came with your system and was possibly correct at the time.  If you have a look in database explorer it will frighten you when you see the incorrect data.
The reason the update thread is running is because the records supplied with the box are a couple of years out of date, hence this thread and the reason why the updaters are hard at work as we write, have a read back through the thread.
Mind you when the new navdata file comes out you wont have the problem then with the particular record.  Before you ask I dont know when that will be but hopefully it will be soon as it is in test.
Hi Alan, as you are talking about the hard work of the updaters, here are four further hex codes from me to add/investigate.
4CA80A unfortunately nothing more found
A74ED3 N570EF nothing more
3D1DEA D-EJOS C210 Cessna T210N Turbo Centurion Private 21063980
3C4B09 nothing more
btclarke
#821
Thanks for the feedback Alan!
I suppose I shouldn't have been surprised, and given how long the dbase update threads and the unhappiness over outdated data has been around.
However this requires more time than I currently have to worry about sifting through my 15 or 20 000 records...
I won't hold my breath for a new database.
That being said, thanks for your patience with helping the users sort it out.
[PS: I think the B722's were phased out before ANRB was around...]
Bob SEN
Hi Alan
dont know if this one has been done yet
400B75 is registered G-CGOA (ex G-JMDW) ..........
cheers
Bob
1/2 a mile South of EGMC/SEN
BT, I wouldnt worry it wont be too long.
