Is this a known bug?
Started by anodes, December 05, 2010, 08:45:12 AM
anodes
A question on range, when setting the range in the advanced filters with the lat & long settings, then saving as a .flv, filter extension file, works as it should, but after closing AirNav & restarting the program the range filter cannot be used because there appears to be a default setting of lat 39.75   long -105.00. Is this a known bug?
anodes
Thanks tarbat - thought I was alone on this one. Would you mind if I pm you?
Thanks, Steve
