Upgrading to 1.4 2008
Started by Bigyun2000, March 13, 2008, 02:05:15 PM
Bigyun2000
Hi all
I am a newbie. Just received my RadarBox from Martin Lynch & Sons.  Installed it and seems to be working fine.  However they advertised it as the new 2008 version with 1.4 software.
Unfortunately it isn't, it says it is 1.3 software version 1.01.2 firmware and only 2007.
I run Windows Vista on my laptop and run the program, then i goto HELP and select CHECK FOR UPDATES.  Unfortunately nothing happens.
So how do i upgrade my unit please?
Also is it possible to change the colour of the mouse pointer as its difficult to see?
Tony from Rotherham
Roadrunner
Bigyun2000
Wow Roadrunner that was superfast reply - THANKS.
Downloaded and working fine at the moment.  Still have version 1.01.2 firmware.  Is this the latest please?
I did the firmware upgrade via the download here on the forum and my version is:
1.01.0
I'm sure that your version 1.01.2 must represent the latest factory installed firmware upgrade.  My version works fine, so I'm sure that you will be OK too :-)
Bigyun2000
Hi Allocator.
Thanks for your reply.  I couldn't find the software update for 1.4 until Roadrunner gave me the link. On the Airnav web site it still shows ANRB1.3.
Does anyone have a higher firmware? or is this the latest?
1.01.2 is the latest firmware.
1.01.0 and 1.01.02 and basically the same. Don't worry if you have one or the other it will make no difference :)
