My System down
Started by GreekSpy2001, January 17, 2011, 09:09:44 AM
GreekSpy2001
Started up a couple of time today.  The software is sitting saying hardware checking.  USB drive in device manager says all is okay with driver.  Disabled and enable driver.  no change.  If i unplug the usb then it I get a brief blue flash of the led.
System working ok yesterday.
Any ideas
Graham
Try on another machine if possible and another USB port. If no such luck either contact support and we will give details on a return.
GreekSpy2001
Thnx  Will try that.  However forgotten my password and can't find my original CD sleeve.  Can you advise how best to get it via PM perhaps?
Graham
Yes send us a PM with your RB serial (its on the bottom of your box and starts ANRB..)
GreekSpy2001
GreekSpy2001
Got the pwd logged in on my laptop  (win XP).  Working fine.  So fortunately not my RDB hardware.
Running on Windows 7 64 bit.  Do suggest reinstall of sw or just 64 bit drivers?
Thnx
Graham
Do a reinstall of your software, something may have got corupted, backup your data folder though first.
Sometimes if something has got corrupted the checking.. sign remains and doesn't disspear, this has been seen on rare occasions.
tommyg
Graham
Yesterday my RB just stopped working, was picking up nothing at all even though system showed everything OK. This is on my Win7 Laptop. Tried restarting RB to no avail, then noticed that my virus checker had scanned the PC, so did a restart of my computer then connected RB and everything started with no probs. This is the first time that my virus scan has interrupted RB. For info using Mcafee via BT.
Trevor
Tommyg
CoastGuardJon
Hi Graham, another possible cause is Windows updates, I found great difficulties with Win 7 64-bit Ultimate, every time an update occurred, RB would cease to function.   Come the finish, I re-formatted HDDs re-loaded Win 7, disabled Updates, installed ANRB, had the normal problem of having to point RB to the 64-bit Drivers, then everything ran tickety-boo (OK!).   I've since found out that my Win 7 is a counterfeit copy, which I notified to Microsoft - giving them my registration code - but the Update problem was there before they knew that!   Try disabling Updates and see if that solves your problem.
GreekSpy2001
#9
Thanks all for replies and help.  Back up running on my Win 7 64bit box with a reinstall of 4.03. Although my flight history for the last 18months has gone.  myflights db file got overwritten/corruptted along the way.
Two things spring to mind that may have been potential causes for the RDB corruption.
Still Radarbox SW causes my machine to crash (BSoD) after approx 36 hours of contiuous operation.
Also Windows Update.  Normally set to manual mode, somehow it got reverted back to automode and after a crash did an update on reboot.  Have the same problem with power save mode on my USB.  Occasionally reverts back to the ON state.  Most frustrating...
Graham
Tonka
Regarding the USB problem;
Most PCs have an entry in the BIOS setup to permanently switch off the USB power saving facility.
Alex
GreekSpy2001
OK will have a look in the BIOS next time I restart
Graham
CoastGuardJon
Hi Graham, I'm still convinced the Updates is the cause of these problems.   Mine has been fine since disabling Updates - and no other problems, so I'm haooy.   Can you try this, it may prove the point.   Disable Updates, then when convenient shut RB down completely, and then let Updates do its thing. When completed, Shut Down and then cold re-start, if any updates have completed installing, start RB and see if it can live with the updates - if RB runs OK, then we'll have a better idea, whether or not it is the auto update process that causes the corruption.   I can't try it myself, because as stated above, I notified Microsoft that I thought I may have been sold a pirated copy of Win 7, and gave them the supplied registration code - each time I log on since reporting it, I get all sorts of messages telling me that I've got a counterfeit copy of Win 7, and can't get any updates downloaded, and it only runs with basic functions.   I thoiught I'd be doing them a favour by reporting this, but instead I get screwed!   I paid £100 for it, seller promptly disappeared and I'm left up the swanny!   I wouldn't bother reporting any suspicions to them again - once bitten...............
CoastGuardJon
Graham, a PS to Tonka's comment above, I don't know about the USB power settings being in the BIOS, but I believe they are availabe from Device Manager - USB - Properties.
HTH CGJon
Tonka
Quote from: CoastGuardJon on January 20, 2011, 01:35:01 AM
HTH CGJon
They are available in Device Manager but the settings do not survive a reboot of the PC - thus the need to set them in the BIOS.
