Author Topic: Alternative cable for Wimo external antena  (Read 14314 times)
CarlosAbreu
  • The sky is not the limit
« on: March 17, 2008, 12:58:53 PM »
Hi to all
Coud yanyone please provide alternative reference cable for Wimo antena ?
The Ecoflex cable included in Wimo’s Kit has large N-conectors that cannot pass through my wall cnx box (only BNC’s or smaller), so I must found an alternative cable that can easly support the amplified signal. wich one do you advise ?
RG58U / 50 Ohms
RG59U / 75 Ohms
RG134 / identical to the one supplied with ANRB
Many thanks in advance and best regards
CA
Station: Primetec PGANRB100514
Antenna: Wimo GP-1090 (AS-1090/BT-1090)
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
davis
  • RANGE
Re: Alternative cable for Wimo external antena
« Reply #1 on: March 17, 2008, 01:41:04 PM »
Hi to all
RG58U / 50 Ohms
RG59U / 75 Ohms
CA
Hi to all
RG58U / 50 Ohms
RG59U / 75 Ohms
CA
NO..NO...NO...These cables have too many losses that frequenzan 1090 Mhz.To R / B does  will 'no signal..The cable must  to be large...I made a big hole in the window
Gianni
CarlosAbreu
« Reply #2 on: March 17, 2008, 03:23:17 PM »
Hi Davis
Thanks for your reply, I know about the strong possibility of loss of data, however at this moment I have an 11m of RG134 cable from outdoor ANRB original antena to the PC and it seems to work fine.
I live near LPPT and with this configuration I can pick up all arrival/departure/in flight aircraft until +/- 80 miles, but this is done with a normal reception, with the Wimo antena is diferent because the signal is amplified.
How to increase the whole for RG58U without too many damage on the wall ?
That's the only way I have to pass the Ecoflex cable indoor to the antena.
I would be grateful for you comment.
Brgds
CA
Deadcalm
« Reply #3 on: March 17, 2008, 04:18:05 PM »
Carlos, I don't think anyone would try and drill a hole large enough to pass an "N" connector through a wall...
With my Wimo antenna, I cut off the "N" connector, drilled a hole just large enough for the cable through my 2' thick stone wall, and re-soldered the "N" connector back on to the cable.
DC
CarlosAbreu
« Reply #4 on: March 17, 2008, 04:25:36 PM »
Deadcalm
That's the option I have to solve the problem, but this means a new N-connector to be resoldered back on the cable.
Can I do it with the same N-connector from Wimo antena ? It doesn't seems a easy work to do it...
Deadcalm
« Reply #5 on: March 17, 2008, 04:37:33 PM »
It's not easy, because the cable and connector are a bit chunky, but I re-used the existing "N" connector - you just need a reasonably hot soldering iron, and spanners or pliers to undo the cable nut.  Failing that, new "N" connectors are relatively inexpensive and easy to acquire.  Either way, consensus suggests that using a lesser cable is a no-no.
DC
« Last Edit: March 17, 2008, 04:43:28 PM by Deadcalm »
« Reply #6 on: March 17, 2008, 04:47:46 PM »
Can you cut the cable 30 cm or so from the plug at the receiver end, then splice the cable, this might be easier than unsoldering the plug and resoldering it?
CarlosAbreu
« Reply #7 on: March 17, 2008, 04:57:07 PM »
Thanks for sugestion it's a good idea, if well done there's no loss of signal.
I will try it if no better sugestion arrive.
brdgs
CA
Cumulus
« Reply #8 on: March 17, 2008, 07:30:17 PM »
Hi Carlos,
Splicing coaxial cable is not recommended as it introduces impedence mismatch and losses . The solderless 'N' plugs for Ecoflex cable are not too difficult to fit.
Instruction in the following pdf documents:-
Ecoflex 10
http://www.ssb.de/englisch/products/koax/e10stecker_e.shtml
http://www.ssb.de/pdf/mont-n-eco10_e.pdf
Ecoflex 15
http://www.ssb.de/englisch/products/koax/e15stecker_e.shtml
http://www.ssb.de/pdf/mont-nm-eco15_e.pdf
Cheers,
Peter
« Last Edit: March 17, 2008, 07:33:07 PM by Cumulus »
CarlosAbreu
« Reply #9 on: March 17, 2008, 09:59:18 PM »
Hi Cumulus
Thank you very much for your suggestion, I will follow it. Just need to check the correct N connector of Wimo antena.
Brgds
CA
tail-wind
« Reply #10 on: March 17, 2008, 10:16:10 PM »
Olá Carlos,
I had exactly the same problem, even worse, i had my boxes mounted out-side (luckilly the algarve climate is user friendly) - but decided to pass the cable through the wall. Made the hole a bit bigger, took of the N-connectors off, which was much easier than expected, passed is and replaced the connecters, which was even easier. So yes, try it, definitely worth it.
Let us know how you get on.
Diederick
CarlosAbreu
« Reply #11 on: March 20, 2008, 11:20:27 AM »
Olá Diedrick
Thanks for your comment, that's waht I'm going to do.
I have bought one male N-Connector, but it seems I need a special tool to place it.
I'm not sure if I can easly replace the original N-Connector from Wimo Ecoflex 10 cable.
In you case how you did it ? Any special detail to take care ?
Brgds
CA
CarlosAbreu
« Reply #12 on: March 20, 2008, 11:59:42 AM »
Cumulus
The N-Connector I bought isn't easy to place, so I decided to order a new one from the SSB site.
Your information it was very usefull, specially the install instructions. Thanks.
Brgds
CA
tail-wind
« Reply #13 on: March 20, 2008, 06:51:02 PM »
What I did was I went to my local radio shop (where I bought both the cable and connector) and aked him to put it all together (had to pay for this, but think it was worth it). Than at home I took the "N" connector of, quite simple, passed it through the wall and just put it back together. Maybe I was lucky, but found it to be very simple.
Carlos, hope you manage, otherwise, I'll be in Lisbon next week-end (hopefully) and maybe can give you a hand.
Diederick
CarlosAbreu
« Reply #14 on: March 23, 2008, 12:09:25 PM »
Tail-wind
Just looking to your post right now, since last thursday I'm updating to a new Windows Vista based PC, this is the first time I come back to forum.
Today it's impossible for me to meet you, I have the family Eastern lunch. When do you come again to Lisbon ?
Thanks for your post, as I told before that's teh correct way to solve the problem.
Brgds
Carlos
