RAF plane
Started by jimjam, April 10, 2011, 03:19:03 PM
jimjam
Just seen an RAF plane on my radar with no photo. Flight number 'test1234'. anyone know any info. appreciated
jamie
Marpleman
Jamie
What was the hex code for it?
Take a look in "my log" to find it - probably doesn't have a photo as it may be either unknown, or as the callsign suggests, could be a test flight, or tactical callsign etc etc
With the hex code, it may be possible to tie it up
Rich
jimjam
the hex code is 400025
400025 is unknown
Marpleman
Where abouts in the UK are you Jamie
Are you near Warton or Yeovilton by any chance?
freqhopping
Probably a ground station.  In the US our ground station hex codes fall under the same allocation range as the military.  They also display TEST1234 for the ID.  Usually there is no altitude or squawk.  Other times it will show an altitude that changes all over the place.
G8VXY
Received a bogus one myself that had a 7700 Squawk.
Alert Time: 2011/03/16 16:32:03
Received Squawk: 7700 (AAAAAA)
Total flight information:
Flight ID: CHAOS042
Registration: VARIOUS
Aircraft: N/A
Routing:
Altitude: 12750
Speed:
Heading:
jimjam
thanks guys and by the way, i live in surrey
