Author Topic: MONTREAL CYUL MAP  (Read 5100 times)
ve2har
MONTREAL CYUL MAP
« on: April 15, 2011, 11:03:59 PM »
Hi, I am using AirNav RadarBox PRO, I am located near CYUL Dorval airport but somehow my map is not aligned properly, that CYUL airport shows on the river. See attached files. How can I correct this?
Thanks in advance.
Robert
    • Rod's RadarBox Downloads
Re: MONTREAL CYUL MAP
« Reply #1 on: April 16, 2011, 12:07:32 AM »
Hi Robert and welcome to the forum.
Annoying, isn't it? There are many airports in RadarBox that appear to be bobbing around in lakes, rivers and oceans. The built-in map is only a rough one, and not very high resolution. There are two solutions. 1 Use the 3D version with Google Earth - that's nice and accurate, but you don't have that, so: 2 - download outlines (or create your own) and add them to RadarBox.
I recently did an outline of Montreal islands here: http://www.airnavsystems.com/forum/index.php?topic=5405.msg63818#msg63818, and you can also get it and an outline of the airport layout from my zip of all the RadarBox outlines on my downloads page here: http://rodb.gofreeserve.com/RadarBox/Downloads.htm
Oops - forgot a third option - use the Satellite Layer (from the Map menu) to download a satellite image of the area. More info on this option here: http://www.airnavsystems.com/forum/index.php?topic=1294.30
Better than nothing! Hope that helps.
« Last Edit: April 16, 2011, 12:13:43 AM by RodBearden »
« Reply #2 on: April 16, 2011, 12:17:20 AM »
Or you can download a Sat map via RadarBox Pro and that should make it a bit better.
We didn't provide a high resolution map as its puts a considerable amount of pressure on your CPU when you have a large area showing. We are looking into techniques to get around this as few cases such as your self have appeared which aren't fully useable.
ve2har
« Reply #3 on: April 16, 2011, 02:25:54 PM »
Thanks for all answers.
CYYZGUY
« Reply #4 on: April 16, 2011, 03:14:06 PM »
Another Dumb question from a newb.  Where and how do you get these satellite maps?
I would kill for a satellite map of the Toronto/MIssissauga area where CYYZ is located.
regards,
40" LED Monitor
40" LED Monitor
nortonbeak
« Reply #5 on: April 16, 2011, 04:01:17 PM »
Map > Satellite Layer > Download
« Reply #6 on: April 16, 2011, 04:41:23 PM »
For details see the link in my first reply.
