Author Topic: AIRPORT WEATHER FORMAT  (Read 2582 times)
ve2har
« on: April 18, 2011, 10:57:29 PM »
Hi, is there any way to view airport weather information in different formats.
Robert
    • Rod's RadarBox Downloads
Re: AIRPORT WEATHER FORMAT
« Reply #1 on: April 18, 2011, 11:32:55 PM »
Hi Robert
THere are three formats available - just click the little arrow on the right of the Weather button and take your pick. "Decoded METAR" is the one that I can understand ;-)
Many users have asked AirNav for that to be de default, but it doesn't seem to ever happen!
ve2har
« Reply #2 on: April 19, 2011, 11:28:22 PM »
Hi Rod,
Thanks for information. Here is my screen:
« Reply #3 on: April 20, 2011, 12:30:45 AM »
Hi Robert
First of all, I strongly recommend that you upgrade to the latest version of RadarBox - you can do it for free here http://www.airnavsystems.com/RadarBox/support.html - use the link for the full version of RadarBox Pro - not the Upgrade version. Remember if you have Windows Vista or 7, don't use the suggested installation folder - remove the "\Program Files" bit and install in C:\AirNav Systems instead.
Once you've upgraded, you might find the Weather button becomes usable. If not, you may have a screen resolution problem - go for the mamimum possible and see if that helps.
HTH
