New Navdata.db3 - 20110418
Started by AirNav Development, April 19, 2011, 06:14:18 AM
A new navdata.db3 installation is now available:
http://www.airnavsystems.com/download/ANRB/DBUpdater/ANRBDBUpdater20110418.exe
Changes: New/Updated aircraft table;
One more time this has been the result of an amazing work developed by our database updaters volunteer team.
Notes:
1- This installer copies your existing navdata.db3 file to navdata-backup.db3 so you can keep a copy/backup of your previous file;
2- It then replaces your existing database with the new one;
3- A new updated airport database is included;
4- It is important to note that these periodic navdata.db3 releases do not intend to replace the work we will do on the RadarBox client application which will include an auto-update feature and some other requests made by our users and database updaters team;
Hope you enjoy it.
AirNav - the bug that stops me installing the update in the correct place still exists. The Back button doesn't allow correction of the installation path. I guess there's a Registry entry that I could correct, but I don't enjoy mucking about with the Registry.
You agreed last time that this needs fixing. PLEASE do it!
Pinza
Completely agree with Rod - much as these updates are appreciated, it must be a high priority to install them correctly and not the 'black magic' nightmare of letting it install into the black hole of a virtual store and then finding relevant file and copying into correct location!
What is it with these updates ! Every time there done it turns into a complete shambles. Just downloaded the latest one with the RB not running as advised. I go back on and what do I have :
In database explorer - nothing.
In My flights - only Mode S and flight ID, no Registrations , no aircraft details, no silhouettes, no photos, no aircraft histories.
Network - everything ok.
Do I now have to do a complete install/reinstall to get back to where I was. Please AN no more of these updates. What a joke !
A far from well pleased user !
We apologise that we were unable to add the functionality to change the location in time for the release. We hope to do that for the next one.
EK01,
Not sure what has happened your RB, but the install only affects navdata so it shouldn't affect aircraft histories. Did the same issue happen when you installed the last update?
Pinza
Thanks for latest update, Support. Despite my slight whinge last night about where it installs to by default, I just let it do its thing and copied the file across to where I really wanted it to be. Slightly messy - but working for me perfectly!
Thanks, Support - this bug really seems to be flummoxing the folk who have installed in the virtual store and then realised the error of their ways. Heaven knows where the upgrade goes!
Quote from: AirNav Support on April 20, 2011, 06:48:37 PM
EK01,
Yes it did but finally managed to fix it although not sure how. Any suggestions gratefully received.
Finally up and running again but only after a computer expert (she who must be obeyed) managed to sort it out. It appears that the updates are downloading themselves into the wrong folder resulting in them being in the system but not operating correctly or in this case not at all.
The moral as far as I'm concerned is to ignore any future updates and to wait for a complete new version to emerge whenever that might be !
#9
Ian,
I expect you are using Vista or Win 7 and are suffering from the virtual store problem.  See http://www.airnavsystems.com/forum/index.php?topic=6020.0 for details as well.
Its a matter of letting it download to where the installer puts it an dragging it across to the correct location.
Hopefully Airnav will have fixed the installer by the next update and will let users put it to wherever they have locsted their data file instead of the default.
Alan,
I am using Vista but install everything into AirNav systems only ie not including 'program files' which seems to put it into the virtual store however the installer seemed to put it somewhere else.
As you say hopefully Airnav will have this fixed for the future and sooner rather than later.
Marpleman
I had a nightmare with the last update a month or two back, and ended up letting "nature take its course" and then simply did a search for all navdata files on my laptop, to find where the so and so had downloaded to!!
Then as Alan suggested, did a straight copy and paste to the data folder where AirNav was loaded - this was on Vista also,works a treat now, so suppose the moral is ignore what it says on the tin
I had problems in initially loosing mylog data and all my existing pictures also, but all happily restored now.
I hope this software issue doesn't deter too many users from accessing the new file, and especially the fantastic effort the team have put in, continually improving things week by week, but agree that a straightforward fix would be most appropriate
Have a great Easter all - let's hope the weather holds
Rich
Rich,
Unfortunately as you may be aware I now live in inland Spain midway between Alicante and San Javier airports (about 35-40 minutes from both). I say unfortunately because for the last 10 days or so the weather here has been awful. Truly envious of you guys in the UK sunshine. I do feel sorry for people who have come here from the UK for the Easter holidays looking to get a suntan. What a waste of money !
Dont be envious about us here in Scotland Ian, its the Easter holiday weekend so the weather does its usual and has broken here, dull and dreich and miserable today and likely to last all day.
But agree with the poor people looking to get away for some sunshine.
Alan,
Thanks for that. It's cheered me up a bit.
