Author Topic: Where is 'My Log' saved to?  (Read 2418 times)
Matt Taylor
« on: May 03, 2011, 01:57:45 PM »
I am currently in the middle of moving home and will be without my desktop pc for some time so I am now using Radarbox on my laptop which is a few years old and is running very low on memory in the C drive (D drive has plenty of space though). My new location is just 2 miles south of LHR so I am getting a huge increase in my daily log compared to my previous location.
Is there a way of saving my logs to the D drive or transferring them to my desktop when I get the chance? It is quite likely I will do a re-boot on the laptop soon so as to speed it up and clear some space but I don't want to lose my daily log data if possible.
Hopefully someone has some answers!
Re: Where is 'My Log' saved to?
« Reply #1 on: May 03, 2011, 02:03:25 PM »
Hi Matt,
We assume you have installed RadarBox to your program files directory. If so if you go to Program Files\AirNav Systems\RadarBox\Data you should see quite a few files. You should see a MyLog file which you can copy to your D drive.
You might want to copy the whole data folder instead.
You can then install RadarBox to your D drive and copy the data folder to your D drive directory and it will continue to save it there.
Matt Taylor
« Reply #2 on: May 03, 2011, 02:15:13 PM »
Thanks, I thought it might involve re-installing on D!
