Author Topic: Mode S generator - pattern  (Read 5403 times)
marcdeklerk
« on: March 18, 2008, 02:28:58 PM »
hi there guys, I was wondering:
The mode S code of each aircraft is unique to each aircraft, in South Africa where I a located, I have noticed the folowwing:
ZS-AAA  ---- 008000 ?
ZS-ZZZ  ---- ???????
so the rest of the registrations should be between 008000 and ?????
ZS-ABG 008031(the closest to AAA that I have logged)
ZS-ZXX 00C482 (the closest to ZZZ that I have logged)
ZS-SLA 00B0B7
ZS-SLB 00B0B8
ZS-SLC 00B0B9
ZS-SLD 00B0BA
ZS-SLE 00B0BB
ZS-SLF 00B0BC
there is a pattern
ZS-SJR 00B094
ZS-SJS 00B095
ZS-SJT 00B096
ZS-SJU 00B097
ZS-SJV 00B098
could some maby generate all the registrations with their Mode S? and then I can have a look at the one's thats not updated by the Auto-Populate feature and add them in myself?
will this work?
« Last Edit: March 18, 2008, 02:31:28 PM by marcdeklerk »
Re: Mode S generator - pattern
« Reply #1 on: March 18, 2008, 02:34:10 PM »
This SQL will give you the list of 80,000+ aircraft, listing their ModeS hexcode and registration:
SELECT DISTINCT
  aircraft.MS,
  aircraft.AR
FROM
 aircraft
ORDER BY
  aircraft.MS
Although I suspect there'll be many exceptions
« Reply #2 on: March 18, 2008, 02:43:12 PM »
Quote
Nice idea, but it's not quite that simple!
Mode S allocations to registrations are often quite random, even though certain code blocks are allocated to particular countries or operators.
steveb25
« Reply #3 on: March 20, 2008, 04:14:46 PM »
Apologies slightly off topic
what is the wildcard character for sqlite?
« Reply #4 on: March 20, 2008, 04:33:12 PM »
Either * or %
steveb25
« Reply #5 on: March 20, 2008, 04:44:35 PM »
Thanks tarbat
I was trying to use '=' and not 'like' to sort data
