Author Topic: Report generation  (Read 2169 times)
Geot
Report generation
« on: May 27, 2011, 03:44:54 PM »
I manually generate a report daily to two addresses. Over the past few months, approximately once every ten days or so, it fails to send, Reason given is Message failed, check background software (anti-virus/firewall), etc.
I keep trying to re-transmit that days report several times, always with the same response, while on all other days it has gone smoothly at first attempt. So I am suspect of the anti-virus suggestion. Could there sometimes be a buried "bad character" that upsets the Reporter?
Geot
Re: Report generation
« Reply #1 on: May 27, 2011, 04:10:24 PM »
The same happens to me on occasions and I find that when it occurs if I send the same report the  next day it goes to the recipient ok for some reason
Geot
« Reply #2 on: May 28, 2011, 01:22:55 AM »
Well it never seems to work for me - I try several times with 5 min intervals, nothing. Try next morning again several attempts and I give up. And the problem is you cant go back more than yesterday; if it does not go the next day, that days report is lost.
Geot
« Reply #3 on: May 28, 2011, 06:35:35 AM »
...That's why I think there is the urgent need for a "automatically generate and save to file" function in addition to the existing mailing option!
