Author Topic: my flights  (Read 2208 times)
oldun
my flights
« on: May 27, 2011, 10:15:15 PM »
can anybody help please, i have just turned my r/b on as normal and there are no my flights showing , it says hardware connected the process flights is ticked the r/b shows the green power on, the blue light is flashing, but no signal light, network is working, messages  per sec shows zero, i have loaded the cd in again and checked the usb, the antenna is ok,  this is a new box i am not that clever on electronics please help     jeff.
Re: my flights
« Reply #1 on: May 27, 2011, 11:20:57 PM »
You seem to be in the UK, if you don't have good coverage you can easily be seeing little or nothing at this time off night. Have a go in the morning and get back to us whether its the same.
oldun
Re: my flights
« Reply #2 on: May 28, 2011, 10:20:58 AM »
hi there  thanks for the reply, i usually get quite a few my flights at that time of night i'm like a bat up at all hrs, just switched on at 11:00 uk time usb light is flashing, signal light itermittent, and 3 to 4 my flights which are leveled or ground  thanks  jeff.
