Problem running in Windows 7
Started by dudbaker, June 12, 2011, 01:09:20 PM
dudbaker
Hello
I just loaded a new Dell lap top and I have a caption in bottom left saying Hardware: not connected.
Any help?
Dudley
Dudley Baker
Stansted
G8THH
Hi Dudley I take it you downloaded and installed the latest drivers from the support page?
http://www.airnavsystems.com/download/ANRB/drivers/ANRB64bitDrivers.zip
dudbaker
I copied every thing from my old computer to the new using a memory stick.
Dudley
Dudley Baker
Stansted
G8THH
Are you saying your just copied the folders across into the new machine and you haven't installed it the normal way or installed the drivers?
dudbaker
#4
Normal way.  Is this puting in the disc supplied?  How do you install drivers?  I should add that this computer will not connected to the internet.  I plan to use it at Fairford next month.
Dudley
Dudley Baker
Stansted
G8THH
The normal way is either via the CD or downloading the software and installing it.
The Windows 7 server drivers are at
dudbaker
Hi again
Some progress.  I found the drivers and now the bottom left caption is saying Hardware Checking.  I do not think the CD is an option as I have had it some years.  I am now considering down loading the whole thing but could only find the 3d option.  Also, I will need to download to one computer and copy to the laptop.
Dudley
Dudley Baker
Stansted
G8THH
Dudley,
Download the 3D it runs in 2D if you dont take up the 3d option. its the current version 3.13 or 4.03
Are you sure the laptop isnt internet capable its very hard nowadays to be able to by a laptop without it.
dudbaker
Thanks.  I am sure it is internet capable.  It is that I am out of my comfort zone.  When I tried to have 2 computers on at the same time it took a hour on the phone to NTL to sort it out.
Dudley
Dudley Baker
Stansted
G8THH
dudbaker
I have now downloead the full download.  Cpoied it to stick and then installed on lap top.
It put in a file call program files x86.  Now I have found 3 ways to open it.
1.  Use main icon.  Result Harware: not Connected.
The next 2 are via Windows Explorer
2.  Airnav Radar Box then ANBR.  Result Harware Checking.
3.   Airnav Systems then Airnavbox then ANBR.  Result Harware not connected.
Dudley
Dudley Baker
Stansted
G8THH
Dudley, remember to download the drivers as well as the program. Use the links above to get them.
Hi Dud, go into Control Panel, Device Manager and see if ANRB is showing under USB, you may need to install "updated" driver, by pointing the device manager to the ANRB driver file.
dudbaker
Dudley Baker
Stansted
G8THH
Hi Dud, to help others, how did you resolve this problem please?
