chewycanes
Morning Alan
ACD841 From AF is N927AX but FAA seems to have changed reg to N790UA.
Brian
Hi Brian
ACD841 is in the d/b as N927AX.  It was previously N790UA with United,the registration change being Authorised 2/7/2011.
The FAA are a wee bit tardy in updating their records at times.
chewycanes
I had five that needed populating of which three were known a/c using old codes. I tried populating multiple times and one cleared leaving ACD841.
As soon as i got your response i pressed populate and guess what...  populated straight away.
Weird ? Or do you have mystical powers.
Brian
54901 - Jim
Good afternoon, Alan!  Here's an update:
A83C87 / N63MS / RV9 / Van's RV-9A / Schnur Burton J III Trustee / 90768
Thanks!
KOSH - Oshkosh, Wisconsin USA
Chris11
00600D C9-EMB E190 Embraer ERJ-190AR LAM Mozambique Airlines 19000309
Afternoon, errata:
78080A and 780809 are both in the db (have populated to be more precisely) as B-6836, but 78080A should be B-6839.
chewycanes
Afternoon Alan
386C7B No data
600096 Callsign RNV5077 Queried on ModeS forum but no result yet.
508255 Callsign URALA but no other data.
Do your magic.
Brian
Hi Brian,
Nothing on 386C7B
600096 courtesy John Hargreaves EK73771, Boeing 737-55S, c/n 28471/2885, Armavia
508255, UR-ALA, Embraer EMB 500 Phenom 100, c/n 50000254, Embraer EMB 500 Phenom 100 out of Prestwick on delivery and was added to the d/b yesterday when it left Brazil
Evening, finally the unknowns from Thursday:
0063B5 (Mozambique / flight id: BAE52 / BAE: BAe Systems (Corporate Air Travel) )
3D375B D-ETFF DA40 Diamond DA40-NG Private CN:? (Mk1EB: 28th August 2011 / http://www.oshkosh-web.net/spotterbrowser/imgview.php?id=2490 )
3E1988 D-IAWE C425 Cessna 425 Conquest Private CN:? (airframes / Mk1EB: 2009 / http://www.spotting-pictures.de/LEJ-03-.-01-.-2009.htm )
3E6C5A D-KGFQ G109 Grob G-109B Aero-Club Hof e.V.  6245 (airframes / http://www.aeroclub-hof.de/acmsgflugz.htm#g109 )
3EA1C1 (Germany Air Force / Tactical / flight id: GAF996)
3EB8C6 (Germany MIL / Tactical / flight id: EIFEL & SKULL)
3EBC1B (Germany)
3F7B2D (Germany MIL / Tactical / flight id: TA56T)
3FAC6E (Germany MIL / Tactical / flight id: GHOST)
3FB432 (Germany MIL / Tactical / flight id: TRALL1)
3FB70F (Germany MIL / Tactical / flight id: GHOST2)
3FBF79 (Germany MIL / Tactical / flight id: ARAL)
3FF0C0 (Germany)
400BED (tracked with flight id: DEXHV and with flight id BAW887, but this one should be a decoding error of G-EUXE 400AFD)
502C7A (Latvia)
89406E (Bahrain / flight id: GFA9000 / GFA: Gulf Air / A9C-AM  A320-214  c/n 4827 <-- already in db)
A0554D (already in db)
That's all from Thursday. Have a nice Weekend!
From Today evening:
4B178E (Switzerland)
600096 (Armenia with flight id RNV5077 / Start  position: N50 17.0 E008 25.0 End position: N50 16.3 E008 31.3 the very outer edge of my southern reception area)
Hi Ingo,
0063B5, Replies on the mode_s forum show that to be G-TYPH, 4063B5, BAE146 miscoding.  On the way out as BAE51 it used its correct code
400BED decodes to G-VSPN which was written off in Trier
502C7A unknown to me
4B178E decodes to HB-IXY which becane D-AEWA which to my knowledge is in storage at this time
600096 EK73771, Boeing 737-55S, c/n 28471/2885, Armavia
Thanks again Ingo.
