Blueboy
Hi Alan, don't know if this has been flagged up or not.
AAE279  N800GF  Cessna 525A CitationJet CJ-2  c/n 525A-0038  ex. I-IMMG
J.D
Hi J.D
Many thanks, just registered yesterday
Morning, the unknowns from Friday:
341688 (Spain)
3C48CA (Germany)
3D0DFA D-EDNU DO27 Dornier Do-27B-3 Deutschen Lufthansa Berlin-Stiftung  401 (airframes / http://www.dlbs.de/de/Die-Flotte/index.php )
3D1177 was a D-EEWD BE33 Beech F33A Bonanza Private CE-905, but was written off 17th March 2010 because of damage beyond repair. Seems to be a new one.
3D14BE D-EGCK G115 Grob G-115 Private C/N:? (airframes / Mk1EB: June 2011 / http://jetphotos.net/viewphoto.php?id=7138510 )
3D1DF3 D-EPJB, Piper PA-28-235 Charger, 28-7310007 (Posted April 2011, but is not in the db and does not populate. Further the registration may/should be D-EJPB instead of D-EPJB)
3D3B72 (Germany)
3F7510 (Germany MIL / Tactical / flight id: PANTER)
3F8359 (Germany Air Force / Tactical / flight id: GAF674)
3F9380 (Germany MIL / Tactical / flight id: TA20 & TA67)
3FA6E3 (Germany Air Force / Tactical / flight id: GAF292)
3FAF63 (Germany Air Force / Tactical / flight id: GAF994)
3FBBF7 (Germany Air Force / Tactical / flight id: GAF141)
3FF00E D-MLRD GX Remos GX Private C/N:? (Mk1EB: June 2011 / http://www.airliners.net/photo/Remos-GX/1969649/&sid=6bd7795dd79b464d91286114c17d8205 ) <-- I'm not 100% sure, whether this is the correct HEX or not.
4009C1 was according to airframes G-TTOF an easy jet A320, but this one was re-registered to EI-ELD and is now with AviaNova.
400B4E was according to airframes G-NRYL a M20P of Deltamood Ltd, St. Helier JE CI, but was re-registered to OO-GYL.
4249CF on mode_s mail archive this one is stated to be:  VQ-BIX CRJ2, c/n 7539, IrAero
473400 is a 100% decoding error of HA-LPD an A320 of WizzAir.
49D0A1 (Czech Republic)
A19888 N2013N BE23 Beech C23 Sundowner 180 GK Aviation Consulting Inc, Wilmington DE M-2070 (airframes and several others)
A48A40 (would match N392AJ, but no further Intel on this registration. So, it's a miscode or a decoding error.)
D-ELAX a FDCT Flight Design CT-SW is still using wrong ICAO24 HEX of DE5000.
That's all from Friday.
From today early morning:
4249D0 should be VQ-BIY  CRJ2 Bombardier CRJ-200ER 7546 (libhomeradar / Mk1EB: March 2011 / http://jetphotos.net/viewphoto.php?id=7083438 )
4405CC (Austria / flight id: VJS201 / VJS: VistaJet )
One more:
3D1EAB D-EJWD EUPA Europa Europa Private CN:? (airframes, Mk1EB: August 2010 / http://www.flickr.com/photos/b752/5033557779/ )
chewycanes
Morning Alan
3CDF2D D-CLUZ LJ40 ? (from GA)
4CA15F EI-CVR AT43 AER ARANN (from GA)
Brian
#1221
Two more:
3E6BD8 D-KGAQ SF25 Scheibe SF-25C Rotax Falke Private CN:? (http://www.storm-chasing.de/forum/index.php?page=Thread&threadID=2449)
3E69AC D-KFFG SF25 Scheibe SF-25C C2000 Falke FSC Wiesbaden "Maikaefer" e.V. CN:? (http://www.fsc-maikaefer.net/)
X
#1222
Not populating on delivery en route Indonesia OTT f/l 350
* 8A02B3 PK-MDT Boeing 737-522 Merpati              2011/09/03 14:16:29
Not populating in service en route OBBI-OOMS
* 89406E A9C-AM Airbus A320 Gulf Air
X
Blueboy
Hi Alan, this one has turned up at Prestwick.
N933RA  B200  ACF246   c/n BB-933     ex. D-IDRF
J.D
orkney
Hello All
That is all the above that I can get details for attended to. I will be doing these until the 16th as Alan is off on a cruise.
Thank you
Andrew
chewycanes
Hi Andrew
Well deserved break for Alan (a Cruise round the scottish isles i assume Lol)
I am sure you will be upto the task as you have in the past.
Brian
flygfantast
LN-KKI is the d/b as WFU stored, but it's active again and still with Norwegian.
Niklas
Cable: Ecoflex-10 (10m+1m)
orkney
Hello Niklas
I have removed the WFU stored now.
Thank you
Andrew
Morning, further unknowns from Saturday:
3C48F5 (Germany)
3C546D (Germany)
3D17F6 D-EHIC
3D1E77 D-EJUD BOLT Steen Skybolt Private C/N: ? ( Mk1EB: http://www.flugzeugforum.de/forum/showthread.php?63786-Flugbetrieb-in-Augsburg-%28EDMA-AGB%29-2011/page55 )
3D3B72 D-EUTM
3D4200 an 100% decoding error of D-EXIL 3D423F
3D54B4 (Germany)
3D762F (Germany)
3F58AE (Germany MIL / Tactical / flight id: DIXI29T)
3FEB98 D-MAYR CH70 Zenair CH-701 STOL Private CN:? (http://www.flugzeug-bild.de/name/einzelbild/number/22677/kategorie/flugplaetze~deutschland~tannheim-edmt.html / http://www.ch701.de/html/d-mayr.html )
76CCC3 (Singapore)
B449A4 (No country allocation / flight id: 2H_ _ _ _U)
Addition(s) to Saturday unknowns:
3DE9B2 (Germany)
800493 (a 100% decoding error of 800497 VT-VJL a A332)
