X
#1725
Quote from: orkney on October 06, 2011, 09:55:41 AM
Hello X
N3114P   is a strange one as I am not sure about the quality of the data from the FAA about the ST75. The ST75 was supposedly registered in 2002 and is still registered. The P28A was registered and deregistered in 2006 so according to the FAA Two aircraft must have been active with the same reg at once.
Thank you
Andrew
To make matters worse A6-FSA the PA28 sometimes uses N3114P as its call sign!
A34D7A  N3114P                   N3114P  PA28  Carl W Hays          2011/09/30 11:34:40
You can see the confusion caused by this aircraft, given up changing it to A6-FSA!
X
orkney
Hello X
N926FD is added now. Thank you
Andrew
Bob SEN
Hi Andrew......... just touched down at SEN/EGMC is A0B5C6 ......... s/be NI45FF Bae 146 c/n E2136
cheers
Bob
1/2 a mile South of EGMC/SEN
orkney
Hello Bob
That one is in now.
Thank you.
Andrew
YXUphoto
Just wondering if the DB could be updated for C-GRXO.  The server keeps changing the airline name to blank, but should be "Ornge Air".
thanks.
orkney
Hello YXU
That is now fixed.
Thank you
Andrew
X
#1731
Hello Andrew
Not populating
513012 Bosnian unknown is back
C0454D
3829BA AIB03YO     Airbus test registration
X
orkney
Hello X
The only one of them I can find is the Airbus test.
Thank you
Andrew
X
Andrew
Not populating on approach is TAR327 02A190 which according my list the other day should be TS-IMQ
PS noted it used old code only two days ago so box must now be swapped.
X
orkney
Hello X
It should be populating as I entered it on the 2nd of this month. The network did go off for a minute or two a few minutes ago so it might have something to do with it.
Thank you
Andrew
X
Andrew
Just a point noted on the new d/b, previously KC10's appeared as KC10's now they are appearing as DC10's and likewise the USAF AWACS are now appearing as E3TF's (I had changed all my USAF to E8B or E8C in old db).
Thankfully it appears you are doing what I did when updating C17 and K35's instead of BKA and BKC etc, thought I was in for a very long session changing the AT column!
Apart from these small details (which I can live with) I am extremely happy with new updated db.
X
X
orkney
Hello X
I am glad you are overall pleased with the database.
By the way DC10 is the correct ICAO designator for a KC-10 and  E3TF is the correct designator for the Boeing E-3A Sentry, Boeing E-3B Sentry and Boeing E-3C Sentry
Thank you
Andrew
X
Andrew
Thought there was a good reason for the change, does the same apply to B737 (C40) and B752's (C32) operating for USAF now appearing as B737 and B752 etc, etc ?
X
orkney
Hello X
A Boeing C-40 is indeed B737 and Boeing C-32 is B752. You can check ICAO designators here on the ICAO website. http://www.icao.int/anb/ais/8643/
Hope this helps.
Andrew
chewycanes
Evening Alan
406606 G-RADY CRJ850 ex D-ATRI ? (from ModeS forum)
Brian
