From Thursdays Log (Unfortunately I didn't received a LOG from Wednesday)
3D15B9 D-EGMB C172 Cessna 172 Flugschule Pegasus (http://www.pegafly.de/flugzeuge__charter/cessna_172_d_egmb/index.html)
3D371B (Germany)
3EB2E4 (Germany / flight id: SW54)
3F4381 (Germany Air Force / Tactical / flight id: GAF011)
3F44AC (Germany Air Force / Tactical / flight id: GAF183)
3F7617 (Germany MIL / Tactical / flight id: EARL)
3FAB89 87+09 B105 MBB Bo-105P German Army 6109 (airframes)
3FAC00 (Germany MIL / Tactical / flight ids: TA57T & TA68)
3FB022 (Germany Air Force / Tactical / flight id: GAF777)
3FEBCD D-MKMN
3FEC92 D-MRRL GOLF Tecnam P96 Golf Privat (http://www.daec.de/mot/downfiles/2011/Touringgruppe_Start_Nummern.2011.2011.pdf)
3FF06E D-MNYC
4841D3 (Netherlands)
AE0447 (USA)
That's all from Thursday.
Finally the unknowns from Friday:
152AD6 (Russian Federation / flight ids AZS2001 and AZS7006 / AZS: Aviacon Zitotrans )
230040 miscode or misuse / hex not allocated
3C2909 was D-BSKY a Bombardier BD-100-1A10 Challenger 300 but was re-registered to M-BSKY and was again re-registered to OE-HEO of Jetalliance (440474). Should be a new airframes with this HEX, because OE-HEO was recently seen.
3D27E0 D-ENIX was a Heinkel HE72 but now?
3D34B2 (Germany)
3E763E D-KJZA TFK2 AMS-Flight Carat A Private CN:? (http://www.jzacheja.de/)
3F8304 (Germany Air Force / Tactical / flight id: GAF011)
3F8882 (Germany Air Force / Tactical / flight id: GAF787)
3F89A2 (Germany Air Force / Tactical / flight id: GAF808)
3FB395 (Germany MIL / Tactical / flight id: TA46)
3FED8A D-MAKR BREZ Aerostyle Breezer Private (http://i.flugzeugbilder.de/100/25/1292363553.jpg)
3FEE35 D-MSHM
3FF081 D-MEBR (http://aviation-safety.net/wikibase/wiki.php?id=78875 )
400C48 was G-EZIF a Airbus A319-111 CN: 2450 of easyjet but was re-registered to HB-JZQ of easyjet switzerland.
404EC7 was G-JOIE a American Champion 7GCAA CN:502-2005 but was re-registered to D-ELKO
4840D7 (Netherlands)
48B297 (Poland / have this one with two flight ids: GCGTN and 20mins later with SPMWP)
4B15EA (Switzerland / flight id EDW1315 / EDW: Edelweiss Air) A new one for them I guess.
4B169A (Switzerland)
780780 (China / flight id: CCA053 / CCA: Air China International)
880000 known misuse of ICAO24  address: EP-MHF an Airbus A300B4-103 of Mahan Air   (correct hex is: 733506)
A13ED6 (USA / matches to N18FF)
A9E9DF N738MJ C172 Cessna 172N ORION FLIGHT SERVICES INC 17270082 (airframes)
That's all from yesterday.
just receiving
3D1D3C D-EJIA R300 Robin R-3000/160 Private 157 (airframes)
chewycanes
Morning (i assume Alan)
A178A2 N1945L BEECH C23 CBC Energy Corp (from FAA)
3D4C11 D-FBBD P51 Mustang Airfighter Academy (from GA and good photos of it being re-furbished at http://forum.keypublishing.co.uk/showthread.php?p=1764352.
480860 AH64 Apache RNAF I don't know if Andrew looked at my previous post on 480860  but i have done a bit of investigation and i think the database needs checking for all the AH64's from 480850 to 48086C . I can give you what i think they should be but i am sure you would need to check it again. If you want it let me know. All i did was go through AF and then search modes logs for the others.
Brian
orkney
Hello
All above are added or not found.
We are all still looking into what happened with the AH64s.
Thank you
Andrew
chewycanes
Another one:
3FEEF2 D-MMAE nothing more
#292
Brian,
I asked the question on the mode-s forum and recieved the following reply from Glenn Herriot.
Series runs 480850 Q-01 through to 48086D Q-30.
I will check the d/b and update accordingly based on this info.
Many thanks
chewycanes
Thats exactly what i gained from the AF and modes logs.
Hope you had a nice break.
Thanks to Andrew for the work he did whilst you were away.
Brian
Chris11
chewycanes
Hi Alan
43C021 ZE343 TORNADO RAF (from AF)
Brian
Hi Chris,
4CA956 EI-ESA Skyliner has it as A330-223 c/n 1002 ex 5N-ESA  Arik Air cs, ferried 08jull1 JNB-HAM still with 5N-reg applied after seizure, for paint, for Royal Jordanian.
Hi Brian,
I have ZE343 as scrapped at Leeming in 2009.
chewycanes
OK Alan
Was only a short msg count so corrupted.
Brian
#299
Morning, the unknowns from Saturday:
3002E0 was I-AIGL a Boeing 737-33A of Air Italy, but was re-registered to N636AN and transferred to AWAS Aviation Services. I trcked this one with AEI421 flight id. AEI is: Air Italy Polska
3E792C D-KLBW G109 Grob G-109B Private (http://www.abpic.co.uk/search.php?q=D-KLBW&u=reg)
3FEF9D D-MBVG FDCT Flight Design CT SupraLight Private (http://www.flugzeugbilder.de/search4.cgi?srch=D-MBVG&stype=reg&srng=2)
4245FA (UK / flight id: ORB9006 / ORB: Orenburg Airlines /Orenair)
45B642 was OY-MBR a Boeing 737-7L9 of Maersk Air but re-registered to PR-GOA and transferred to GOL Transportes Aereos.
460C75 (Finnland / flight id: OH-ESR / seems to be a Cirrus: http://www.flickr.com/photos/kaltsi/5797484194/)
484A5B is according to airframes a BALL (Cameron N-133 / CN:4676) of Rien Jurg Promotions B.V.   , but I tracked it with flight id PH1120 which was according to airframes a Schempp-H. Nimbus-4DM CN:28 of J.F.C.M. Pas and its hex was: 484A50.
484F17 (Netherlands)
4AC8CD (Sweden)
478373 (Norway)
That's all from Saturday.
