#2865
Alan,
You are quite correct. It is VP-CAN which is ex C-GKOK. The eyes are starting to go. Like you, I have VP-CSN as a Cessna 560.
Edit :
VP-CSN is now OY-KLG with Scandinavia Executive Jet.
Skyliner,
Nwe have 4241C9 over Hungary showing VP-CSN as its flight ID.
X
Have you anything on A6-JIL A300F which might be my unknown 8962D8 departing after airshow where it was parked till last night?
X
X
Everything but its hex, A300B4-605R(F), c/n 626, Rus Aviation.  Further, a question was asked about it on the mode-s forum 21/10 looking for its hex
X
There is little else unnoted locally that goes that high as it was eventually lost at 15000ft, so does fit A6-JIL, which I did not pick up on arrival (maybe from desert direction and under my view), will confirm tomorrow if it is missing from view (l/n last night)
X
X
PS Congratulations on your 4000th reply!
X
X
Another not populating
C0459A  CGAJH
X
Nothing confirmed Skyliner but from the mode-s forum it could possibly be c/n 3356 ex 9H-SNA.  Its now passing FL130 in the Paris area.
Would you believe it X C-GAJH is a Bell Helicopter Textron Canada test registration
X
Not again!
My network froze and could not get its position
X
flygfantast
Alan,
Not populating:
34264E EC-KOV, Cessna 560 Citation Encore+, c/n 560-0768, Bestfly
4AB1F4 SE-LOT, Saab 2000, c/n 2000-013, Golden Air
Niklas
Cable: Ecoflex-10 (10m+1m)
Geot
Could you please edit
C060B3 CGKQC DH8D of Porter Airlines - should read C-GKQC
thks
GeoT
X
#2878
Most entries are Atlantic Southeast Airlines/Delta Connection but some are Delta Connection/Atlantic Southeast Airlines
Again most are Skywest Airlines/Delta Connection but about four are Skywest Airlines/ Delta Connections or
Skywest Airlines/ Delta Connection and a couple are Skywest Airlines/Delta Connections
X
X
AD4024 shows Delta - Air Lines
X
