X
The LLc, Ltd, PLC etc are being done away with
Dont have anything on 7807CA, where did you see it?
X
On network, so I presume over China, probably a new China built Airbus (still have my problems with network)
X
ACW367
Quote from: X on November 20, 2011, 06:27:26 PM
Noted quite a lot of aircraft owners are LLC some Llc (bit like UK's  LTD or Ltd). Normally it is noted as LLC (abbreviation for Limited Liabilty Company)
Same goes for PLC or Plc. Should read PLC (Public Limited Company) as it is also an abbreviation.
Limited is normally abbreviated to Ltd.
X
X
Adding to Alan's comments.  What we have in the DB is generally the full registered name, we know that in many cases this does not accurately reflect the operator name.  With airlines we of course do not use the registered name.  For example Frontier A320 N206FR is registered to the all-embracing: WELLS FARGO BANK NORTHWEST NA TRUSTEE
The general agreement we now have for standarisation is that if the name makes sense without it, as a rule of thumb we remove the LLC, Ltd or Pty from the registered name.  If it doesn't make sense without it we keep it in.
IE
Remove LLC etc:
Action Aviation LLC => Action Aviation
Scroggins Chemicals Pty Ltd => Scroggins Chemicals
Keep in LLC etc:
G-BSLP Ltd   remains G-BSLP Ltd
GIV-SP One LLC remains GIV-SP one LLC
It is a long process for a small presentational tweak, and at the moment we are trying to standardise bigger fish.  Also, many many were added by us from the registered name, before we had full agreement on a standarisation process.  Therefore, we are really only changing them as we find them for other small amendments or to newly added records.  Bear with us.
If there are any specific ones you would like changing - let us know.
X
#2839
ACW367
Thanks for this explanation, I have no issues as what would we do with British Airways PLC or whatever they call themselves now (IAG or whatever with the Iberia link up). Keep it simple seems sensible.
And the mainly US System of using con or reg with LLC is covered by what you state.
X
X
Here we go again on Il-76's (Soviet Transports). This will keep us on our toes in the sandpit!
10234 12395      UR-CIF   Il-76TD   ZetAvia   trf   nov11   ex EK-76777(2)
10234 12414      RA-76403   Il-76TD   Aero Rent   TMP   29oct11   l/n FJR 31oct11, white/grey c/s with titles
.0.34 22748      76503(2)   Il-76TD-90   Volga-Dnepr   r/o   30sep11   line # 94-07; Il-76TD-90VD; c/n already in official list mar97; f/f 15oct11, apart from the tail still in primer; delivery planned for 2012; see c/n 063408209
   ---      3X-GBT   Il-76   GR Avia   no   reports   ferried SAW-KRT 28oct11
   ---      3X-GGX   Il-76TD   all-white c/s, n/t   OSS   06nov11
X
paul tricker
Not populating
AA8404      N777LB     C525B  525B-0369   Cessna Aircraft
Rgds
Paul
Blueboy
Hi Alan, I'm picking up AAE2F1 which shows in DB as N800MA - Super Decathlon but its at FL360 and has N328PC in Flight ID - which is a IAI Westwind and should be A38D50 ( from GAS)
J.D
Thanks Blueboy,
The unfortunate consequence of an aircraft miscoding another ID.  About the only thing we could do is to mark AAE2F1 as various and give no clue to its ID apart from a note in the CO field that the hex is being used by more than one aircraft
X
Still showing in db as US regs, so are miscoding as usual
A7CE16   2289    Air Tractor AT-802   UAE - Air Force
A7CAC8   2285    Air Tractor AT-802   UAE - Air Force
X
X
#2846
Quote from: diddyboy on November 17, 2011, 10:09:59 AM
Some not populating and updates from Sudan.
6835C1 UP-I7642 / IL76TD / 0063471147 Air Almaty (poss Mis-code) noted today at El Fasher
064565 NAF565 / Super Puma AS.332 M-1 / 2239 / Nigerian Air Force noted at El Fasher 12 Nov 11
508055 UR-42426 / YAK-42D / 4520423304016 / South Airlines on Lease to TARCO Air.
Neil
Neil
By any chance have you noted an IL-76 3X-GBT of GR Avia as it was reported ferried SAW-KRT 28oct11. Reg sounds odd to me as normally they are in the sequence 3X-GF and 3X-GG. If 3X-GGT has been noted that would make more sense.
X
X
#2848
Good one for you tonight, seen but was unknown in September, tied up tonight in DXB.
515143 EY-323 AN26  Antonov An-26 Asia Airways c/n 51 06
X
X
#2849
unknown 50FF11 just arr DXB
on Network 7C7A3E
X
