Will do if someone picks up the hex
X
406485 reads Bristow Helocopters! Take a look at Bristow generally as some are Ltd/Ld etc etc others not.
Also look at Boliviana de Aviacon as there are variations.
X
Afternoon,
I have 3DEF14 D-HKUE in the Database as Eurocopter EC135 cn 0527, but without operator. In case you haven't an operator either, the operator is ADAC Luftrettung. Last seen on duty as Christoph 39 on November 19th. Information gathered via rth.info: http://www.rth.info/stationen.db/station.php?id=117
X
#2824
896C0E c/s 1216 noted today so fits the theory that the Herc's have changed to 'new' hex codes
Theory goes that 1211 is now pinging 896C0A, 1213 is 896C0B and 1214 is now 896C0C...time will tell.
Also backing this up is that 1213 which was 89602B has been eyeballed as Avanti 1208.
X
Sure looks like they have been re-coded and thanks for the helocopter!!
X
#2826
CargoJet or Cargojet Airways
Cargoitalia or CargoItalia
CAT or Cat Aviation
X
X
#2827
look at China Southtern Airlines (T after South) and one China Southern Aitlines and one ChinaSouthern Airlines!
X
X
C055D5 shows type as B06
X
andygearystevens
Hi Alan
Re 3CD5F8 D-CIII - I understand the C56X has been reregistered D-CADY and now carries mode S code 3CC066. D-CIII is now an LJ60 cn 60-179 operater unknown. I had them both on the same day which confused me as well.....Rgds Andy
X
China XinHua Airlines or China Xinhua Airlines
X
Hi Andy,
The d/b entries as follows
3CD5F8 D-CIII, Learjet 60, c/n 60-179, Air Independence, apologies didnt notice Ingo stated C56X but its in the d/b as the Learjet
3CC066, D-CADY, Cessna 560XL Citation Excel, c/n 560-5037, Jetline in d/b since 30 June 2010
X
C055D5 C-GGNC, Bell 206B JetRanger, c/n 02123, Chinook Helicopters in d/b since 2/11 so should populate
X
Sorry my fault, I always thought it was a B206, did not realise B06 was correct ICAO code and has populated as such
X
X
#2834
Noted quite a lot of aircraft owners are LLC some Llc (bit like UK's  LTD or Ltd). Normally it is noted as LLC (abbreviation for Limited Liabilty Company)
Same goes for PLC or Plc. Should read PLC (Public Limited Company) as it is also an abbreviation.
Limited is normally abbreviated to Ltd.
X
