Thanks Rick,  I knew it was due out of Southend today but I was out when it went over
Maybe used to be knight but the A340 was delivered in May and has taken over that registration, the database is correct I am pleased to say.
The A310 is now EK-31047
X
Hi Alan
After changing to C:\Airnav all seemed fine but two hours later with network still running, the delay came back again, so switched off network and delay has disappeared!
Must be something else slowing things done when on network.
X
Havent a clue mate, its OK here as far as I can tell.  Is the delay to all your flights then not just network ones?
X
The delay is to all the flights picked up by my hardware
e.g. A6-EMP B773 was seen by me physically departing at 2000ft, but hardware did not report until it was on on the horizon at 6000.  Hardware then reported position and height showing where I first saw it over a minute earlier.
Switched off restarted and next departure was exactly where he should have been, so seems like an issue when running on network.
X
chewycanes
Hi Alan
3E1A80 was issueing callsign D-IBFS so it may have been re-issued.
Brian
#561
Thanks Brian,
I will keep an eye out for it, nothing on Aiframes or GAS other than the hex/registration combimation.
X Maybe you should drop an email to support.  [email protected]
X
That's who I was dealing with when I first noticed it this year and was never really answered then box went back after the lightning incident, will try again and thanks for helping today.
X
X
FYI, one of our strange UAE Mode S numbers (basically back to front) showing up. Most Falcon Aviation Services BE19's do this for some unexplained reason.
7A8691           A6-FCD  BE19  Falcon Express Ca... 2011/07/21 10:09:23
7A8691           A6-FCD  BE19  Falcon Express Ca... 2011/07/21 16:34:11
X
Yep got that one in the d/b X
X
I think I had to manually imput these in Dhaka
BANGLADESH AIR FORCE C130'S
702C01  S3-AGA C130
702C02  S3-AGB C130
702C03  S3-AGC C130
702C04  S3-AGD C130
X
Good Afternoon here are my unknowns from Tuesday:
3D05D9 D-EALT C172 Cessna 172 Skyhawk Private CN:? (source: Wikipedia, so the Intel might be outdated)
3D18C2 D-EHPY
3D3E72 D-EVXA IMPX XtremeAir Sbach 300   Private CN:? ( http://www.luftfahrtclubbraunschweig.de/picdb/Andreas-Privat-XtremeAir-Sbach-300-D-EVXA-Braunschweig-Wolfsburg-BWE-4776.html)
3E8804 (Germany MIL / Tactical / flight id: HAWK)
3EA16D (Germany Air Force / Tactical / flight id: GAF699)
3F70D7 (Germany)
3F807C (Germany Air Force / Tactical / flight id: GAF640)
3F89D1 (Germany Air Force / Tactical / flight id: GAF211)
3F9D0D (Germany Air Force / Tactical / flight id: GAF645)
3F9FF9 (Germany Air Force / Tactical / flight id: GAF709)
3FC603 D-OMKP BALL Ultramagic N-210 Balloon Adventure Hambur 210/26 (http://en.wikipedia.org/wiki/File:Ultramagic_%28D-OMKP%29_03.jpg / http://www.ballonfahrer-online.de/bo_datenbank/bo_datenblatt.php?id=1561 )
3FEFCA D-MWHB ALSL Airlony Skylane Classic UL Private CN:? (http://www.abpic.co.uk/search.php?q=D-MWHB&u=reg)
40653F G-EZGP (tracked with flight id: EZY8001 / EZY: easyJet) (Reg. source: Airframes)
408225 (the second time, I wonder which airframe is sending this miscode.)
424173 (tracked with flight id VPCTR / VP-CTR is indeed a Gulfsteam according to this picture from July the 7th this year: http://gulfstreams.zenfolio.com/p123565930/h2EECFB4D#h2eecfb4d )
4BCD6C was according to airframes TC-SKL which is now HL7712. Whether a miscode or a new one.
AA7D59 (would match to N775TX. Tracked this one with flight id UAL903 / UAL: United Air Lines) A miscode I guess.
That's all from Tuesday.
X
440206 I have as unknown
x
X
* 800318  IFC10110                                                    2011/06/04 10:58:17
X
