Author Topic: outlines  (Read 7537 times)
defcon333
outlines
« on: March 19, 2008, 03:31:49 PM »
hi all,
here is a screenshot i got from the dfs. I'd like to have these outlines on my rb screen. how can this be achieved? any idea?
regards
[attachment deleted by admin]
Re: outlines
« Reply #1 on: March 19, 2008, 06:40:19 PM »
Do a search for outlines or Hamburg, it's all there - I'll find the thread and post the links later - off to have my tea now :-)
However, not easy to do what you want I suspect :-(
Re: outlines
« Reply #2 on: March 19, 2008, 10:04:18 PM »
Defcon,
Take a look at this FAQ.  It describes creating airport outlines rather than airspace, but it might give you some pointers.
http://www.airnavsystems.com/forum/index.php?topic=632.0
Bigyun2000
Re: outlines
« Reply #3 on: March 20, 2008, 11:44:02 PM »
Any idea how to import or use these outlines.  I have downloaded loads of *.out files and was hoping for a drop down menu so that i could select which outlines i wanted.
I do select outlines from the drop down menu but all i get is lots of outlines all at the same time.
Any ideas please?
Re: outlines
« Reply #4 on: March 20, 2008, 11:48:21 PM »
You can't I am afraid select the outline files you want in RadarBox. The only way is too only have the outlines files you want in the Outlines folder.
Bigyun2000
Re: outlines
« Reply #5 on: March 21, 2008, 12:01:58 AM »
Thanks.  I did make an Outlines folder and copied all my *.out files into it.  So i guess when i select outlines, it will show everything in that folder.  Is this correct?
Re: outlines
« Reply #6 on: March 21, 2008, 12:58:20 AM »
That is correct.
Re: outlines
« Reply #7 on: March 21, 2008, 07:54:46 AM »
I guess that you are using Bones outline files for the SBS-1?
I contacted Bones and asked him if he was happy for RadarBox users to use his files, and asked which ones were needed.  He is happy as long as he gets the credit and the outlines are not distributed as part of the RadarBox package. Here is his reply:
You don't need all the files in the data set . The only files you need are:
Lower Airway edges file.
All ATZ and MATZ (Military Aerodrome Traffic Zones).
All CTA (Control Area), TMA (Terminal Control Area) and CTR (Control Zone) airspace.
Permanent Danger, Prohibited and Restricted airspace.
Military ARA, ATA, MTA, TRA, AIAA, E3D Orbit and AARA airspace. TACAN Routes.
Airfield plans.
I don't even use all of these.  Yout go to your Outlines directory and add .bak to the files so you can experiment with what you want (e.g. airways.out.bak).  If you need them, you just take the .bak of the end.
You will need to restart RadarBox to see the change in outlines.
Bigyun2000
Re: outlines
« Reply #8 on: March 21, 2008, 09:15:14 AM »
Thanks Allocator and especially Bones for his contribution.
Tony
