Author Topic: New Airnav Radarbox  (Read 18461 times)
vaca05
New Airnav Radarbox
« on: July 03, 2011, 04:56:58 AM »
Hi my name is Larry and I'm new to airnav. I just bought a used radar box on ebay and had a few questions. First of all, how do you get rid of the graph bar below the radar screen? I want to extend the radar screen all the way. I think I bought the 2007 version of the radarbox. Can I still perform driver updates? ANy help would be greatly appreciated. I downloaded the manual but it seems a little different than what the manual is showing in terms of button placement.
Thanks,
Larry
Re: New Airnav Radarbox
« Reply #1 on: July 03, 2011, 06:18:31 AM »
Hi Larry,
To get rid of the vertical graph go to map and untick VerticalTracking view.
Upgrade the software by downloading and installing the newest version from http://www.airnavsystems.com/download/anrb/403/ANRB403Setup.exe.
Download and install the newest database from http://www.airnavsystems.com/forum/index.php?topic=6249.0
I dont know the version of window you are using but the drivers are included in the software except if you are using Windows 7 64bit you would ned to download the drivers for it from the support page.
Have fun
vaca05
« Reply #2 on: July 03, 2011, 06:39:00 AM »
Thanks Alan I will do that. Also can you or any one tell me how to get the split screen display? Like the screen shots I see where one half is the radar and the other half has the flight info. Kinda struggling here.
Thanks.
Larry
« Reply #3 on: July 03, 2011, 06:46:57 AM »
Hi Larry,
Go to tools/interface and chose left or right.
« Reply #4 on: July 03, 2011, 07:22:29 AM »
On the interface is show/hide ticked or unticked?
vaca05
« Reply #5 on: July 03, 2011, 07:30:52 AM »
After I downloaded the new update, all is well. Thank you very much for your help Alan.
Larry
« Reply #6 on: July 03, 2011, 07:53:15 AM »
Any question just ask and someone should be able to help
vaca05
« Reply #7 on: July 04, 2011, 04:21:45 AM »
Can you use your photos instead of the ones used from anet?
Larry
« Last Edit: July 04, 2011, 04:33:13 AM by vaca05 »
« Reply #8 on: July 04, 2011, 05:13:07 AM »
Yes, but you have to resize them to the ratio you get via airliners.net. The file-name must be registration.jpg and if you want to have two pictures: Registration,2.jpg.
Example: D-AIME.jpg & D-AIME,2.jpg
Unfortunately there is the possibility, that this pictures are overwritten by ANRB software. Can't remember the exact details on which occasions that will happen.
« Reply #9 on: July 04, 2011, 06:13:54 AM »
The radarbox looks for pictures in your computer first, if these are available ok, if not is then goes back to the server for them.  The pictures should be 68 x 16.
Chris11
« Reply #10 on: July 04, 2011, 07:18:29 AM »
Also - if you have pictures other data is not updated
« Reply #11 on: July 04, 2011, 07:45:00 AM »
Since there are (more or less) regular database updates available for download, this one could be considered to be a minor problem. Exception: Massive manual Updates to your own (Nav)Database. Anyway this shall be fixed with the next Software update.
Chris11
« Reply #12 on: July 04, 2011, 08:04:54 AM »
I cannot use the database updates as I have far to many local aircraft that still use the ICAO24 of their registration before they were imported.
« Reply #13 on: July 04, 2011, 08:13:21 AM »
200 x 133.
« Reply #14 on: July 04, 2011, 08:40:38 AM »
Sorry about that got mixed up with the silhouettes, thanks Chris
