Can I have access to the data I receive?
Started by AirNav Development, July 11, 2011, 08:50:24 AM
The data received by ShipTrax is available over TCP port 40004 to use for external applications.
The feed works the following way:
1. Your hardware supplies AIS messages to the ShipTrax software.
2. The software decodes the messages and displays the information on the map and list.
3. The software broadcasts every AIS message as received from serial/USB
The message output Format is Raw NMEA AIS sentences.
To see the raw data output, Run Telnet, then type "open localhost 40004".
