AirNav RadarBox 3D but shows AirNav RadarBox Pro
Started by Burnley, July 22, 2011, 09:21:24 AM
Burnley
I received my RadarBox today and it is the AirNav RadarBox 3D.  The CD has the username and password on it and I can use the software fine.  However, at the top of the display it shows as RadarBox Pro when this should be RadarBox 3D.  How do I activate the 3D part?
Hi Burnley and congratulations on joining the club!
You will need to contact AirNav Support: via:
http://www.airnavsystems.com/contact.html or preferably by email: [email protected]
Burnley
John Racars
it does not work with me today as well. It happens overhere some times that 3D will not start.
I can not explaine this. It could be that when I restart the Radarbox later on it will work again...
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Hi John,
See the Server Maintenance thread.  There appears to be some issue with 3D since the work was carried out.
Burnley
#5
I think the network is down, no connections to networked units on mine now at the moment.
EDIT: Ignore, forget to ensure I had the connect box checked!
John Racars
Quote from: Runway 31 on July 22, 2011, 10:09:40 AM
Hi John,
Hi Allen,
thank you for that! It is clear to me thats the reason 3D is not working at this moment. There are no network problems overhere at this moment.
Kind regards, Hans
13 NM East of EHAM
ANRB:
We will bring the server down for 5 minutes to try to upload new software to correct this problem.
My 3D is working again, but now I have problems accessing the AirNav Systems Website, including the Forum.
Appears OK now and had no bother accessing the forum now. It was off however when the server was off so maybe thats what caused your problem Ingo.
All should be Ok now, both the forum and RadarBox 3D.
Burnley
