Author Topic: Sqawks  (Read 2241 times)
Sqawks
« on: August 20, 2011, 03:41:45 PM »
Just noticed that none of the aircraft in 'My Flights' are showing sqawks in the grid. The option is ticked in Preferences. Network flights are showing sqawks ok. Any ideas ?
Re: Sqawks
« Reply #1 on: August 20, 2011, 03:55:10 PM »
Squawk code are shown when a Mode-S Radar interogates a aircraft and it replies back with its squawk as well as other details. If none are appearing it may be the Mode-S radar is switched off at the moment. Which area are you picking up from? others in your location should be able to confirm this.
Re: Sqawks
« Reply #2 on: August 20, 2011, 04:11:07 PM »
AN,
Picking up from SE Spain (Alicante region). Currently have 20 aircraft on 'My Flights' and only 1 is showing a sqawk code. All are showing altitudes. Perhaps ATC are having an extra long siesta today and not bothering to issue sqawk codes at the moment !
Re: Sqawks
« Reply #3 on: August 21, 2011, 05:35:54 PM »
After almost 48 hours with no squawks showing against flights in 'My Flights', I can now report that things seem to be getting back to normal. I currently have 19 aircraft showing and 14 have squawks against them. Something strange has obviously occurred over the last couple of days which has now been resolved.
