Author Topic: Server and Callsign Database News  (Read 3944 times)
« on: August 26, 2011, 03:44:38 PM »
As you may all be aware we've been working hard on the server during the last few weeks.
Fortunately the hard work is starting to bring results: the servers seems a lot more stable in the last 5 days and it getting prepared for the new solutions we are about to start development (once ShipTrax is released which is also happening quite soon as a brand new feature is added).
On a side note the new flight number retrieval routine is working great: in just one week from 109875 new callsign queries 89590 resulted in valid routing information (which means we have a success rate of 81.5% which can be considered great).
We are also preparing a new update to the navdata.db3 database.
Don't forget you can always check in real-time for the hard work of the database updaters team at:
http://www.airnavsystems.com/RadarBox/dbstats.php
Again thanks for all you interest in RadarBox and be sure we are working hard to bring improvements to the system.
Team Spirit
  • AF1981 A380-800 passing T5 enroute CDG.
Re: Server and Callsign Database News
« Reply #1 on: August 26, 2011, 07:15:17 PM »
Many thanks guys, really appreciate the post and must say the hard work is certainly appreciated.
Best regards Dave.
Best regards Dave.
« Reply #2 on: August 26, 2011, 07:18:01 PM »
Glad the new lookup routines are working well.
« Reply #3 on: August 27, 2011, 12:55:44 AM »
The flight number/callsign database success we are having now is the result of the help from users (Tarbat included :-) ).
Netcop
« Reply #4 on: August 27, 2011, 09:14:53 AM »
Now we have correct flight number/routing information retrieval even for pretty small Russian domestic airlines.
Thanks a lot, fantastic job!
Greetings from Russia, Moscow
20.54 nm NWN of UUDD
Amp: Wimo AS-1090
RadarBox24 station: Netcop
« Reply #5 on: August 28, 2011, 05:18:22 AM »
Unfortunately there still some "glitches" in the routing tables, but it's definitely better than in the farer past.
It's not only the marked GMI900. The second one is DLH9PM.
« Last Edit: August 28, 2011, 05:21:27 AM by neroon79 »
