RadarBox Network Coverage Maps Improved
Started by AirNav Development, September 08, 2011, 08:42:01 PM
Quote from: chewycanes on September 09, 2011, 11:15:33 AMDo you think this related to the Google Earth timeouts you mention or some error in conversion of my home town to a Lat/Long within Airnav ?
Most likely it's the timeout problem.  If Airnav could fix the Google Map timeout problem, then the network map would be a LOT more reliable/useful.
chewycanes
Thanks Tarbat
Will now give up looking at it for another year lol.
Brian
The timeout is Google side. You can't fire them a lot (more than 50 in a certain time) of lookup requests without paying and expecting it to take time. However if anyone has any other ideas we would be happy to listen and try them?
#18
Quote from: AirNav Support on September 09, 2011, 11:48:56 AMThe timeout is Google side. You can't fire them a lot (more than 50 in a certain time) of lookup requests without paying and expecting it to take time. However if anyone has any other ideas we would be happy to listen and try them?
If you have the resource to look at this, then maybe consider using BING geocoding.  They don't appear to have the same limitations as Google impose, with limits of 200,000 location entities per job.
You would need to periodically (say every hour) create a geocode job to upload the CITY/COUNTRY data to BING geocoding, wait for it to complete, and then use the geocoded coordinates to create a map on your web page.
More info. at http://www.bing.com/community/site_blogs/b/maps/archive/2010/08/31/batch-geocoding-and-batch-reverse-geocoding-with-bing-maps.aspx
Budgie
The problem now is according to Google earth the Lat/Long it shows now puts me in Essex and not East Sussex.
Make sure you have the Lat & Long in the correct format, Degrees/Minutes/Seconds instead of digital degrees or which ever way it should be. ;-)
chewycanes
Quote from: tarbat on September 09, 2011, 07:56:37 AM
Remember, you can always check if your location is being detected by doing a "View Source" on the web page.
Which website ? How is the procedure "View Source" performed? Sorry for being such straight, but giving hints in that way is in my humble opinion absolutely useless.
chewycanes
Hi Neroon79
It took me a few minutes to work it out.
Basically you right click on the page being displayed and you get an option 'View page Source'.
So if you do this with the 'Network coverage map' displayed you with see some source code and if you scroll down it then list RB users by City and Lat/Long.
Hope that helps
Brian
Quote from: chewycanes on September 09, 2011, 01:57:53 PM
Hi Neroon79
Hope that helps
Brian
This helps a lot. By the way: German version of Firefox: 'View page Source' equates 'Seitenquelltext anzeigen'
Never the less: I have found my Box in the list, but the stated location is 115.05NM with a bearing of 252.71° away from my real location. Why not using the Geo-Coordinates entered in Preferences? To avoid privacy issues round up or round down after first number behind the '.'. This shall move the displayed Position inside a radius of 5NM to 10NM. In my opinion this should be inaccurate enough for any kinds of privacy concerns.
Hi Neroon79
Hope that helps
Brian
Hi Brian, yes, many thanks for this, a heck of a lot more use than the map provided by AN.  My location is fully detailed in preferences, I share to the network, but no bubble west of Launceston - I'm even more convinced this is a waste of time.
eyeinthesky
#25
I agree a wast of time, get a system that works, i think tarbat is the only one making sense at the moment.
Using the Canon 10x30 IS Binoculars with Image Stabilisation, Brilliant job on a clear day.
anorak
CoastGuardJon, have you got electricity that far into Cornwall?  ;-)
Dave. Exmoor, North Devon.
Hi Dave, I have to borrow the battery off the car and keep it charged with a Trevor Baylis clockwork generator!!!   Had one heck of a thunderstorm yesterday lunchtime, shame you can't bottle some of that power.......
Chris11
Where does the info come for the map - I have my lat and long set as my location but the location shown on the maps is about a degree North in the middle of nowhere (ie cannot be based on the IP)
Quote from: Chris11 on September 12, 2011, 04:12:44 PMWhere does the info come for the map - I have my lat and long set as my location but the location shown on the maps is about a degree North in the middle of nowhere (ie cannot be based on the IP)
What you enter as your LAT/LONG has NO effect on the network map - that info. is NOT used.
It tells you at the bottom of the map:
"Red Positions are extracted from the users location (Town, Country) set in the software.  Blue Positions are extracted from the user IP address."
So, was yours a RED or BLUE pin?
