Author Topic: RadarBox Network Coverage Maps Improved  (Read 17539 times)
Rotorsport
Re: RadarBox Network Coverage Maps Improved
« Reply #30 on: September 12, 2011, 07:16:21 PM »
Your IP address cannot always be used to determine your location. In most cases it will show your ISP's location.
54901 - Jim
    • N9JHB.com
« Reply #31 on: September 12, 2011, 07:24:13 PM »
My ISP is in Green Bay, Wisconsin. The closest location in the drop-down choices is Milwaukee, Wisconsin ... neither location shows up on the map.
KOSH - Oshkosh, Wisconsin USA
« Reply #32 on: September 12, 2011, 07:56:14 PM »
Hi Tarbat, I assume when you say "set in the software", you mean entered into Preferences?   If so, then Town, Country isn't a very exact way of doing it, for me on "Auto Detect my Location", it came up with Long Sutton, wherever that is.   Prior to the next box it says "Or enter your Latitude/Longitude directly in the boxes below", which would indicate, that Lat/Long is a direct alternative to the Town, Country entry, but it would appear not from what's been said.   My full details including Postcode are entered correctly - makes this feature even less impressive, or perhaps it's another glitch for AN to add to the corrections awaited list, and yes, I know it's far from a priority, but a gimmick whick doesn't work is far worse than no gimmick at all......................?
« Reply #33 on: September 12, 2011, 08:17:33 PM »
The technicals of what is happening is explained in this thread regarding how google looks-up addresses and how it has a limit.
More importantly the map was made simply to give an indication of what the estimated coverage would be like on the network. We have never stated its accurate, it is just an indication.
Since the map was first brought out users have complained where is my location etc.. and as it states on the map page its just as an indication. Its not meant to be accurate for privacy reasons and its just an indication. We hope that explains things and puts a end to customers wanting to know why there location isn't where it should be.
« Reply #34 on: September 12, 2011, 08:49:10 PM »
In that case AN, eye candy and very pretty but totally pointless.   Thanks for the explanation though, but if a member is prepared to ascertain his/her Lat/Long and then enter the info. in the first place, I would assume they are happy for it to be published, and this brings us back to having a tick box to agree to location being published (and default sharing, which I do, but you don't want that can of worms re-opened yet again!!).
« Last Edit: September 12, 2011, 08:55:20 PM by CoastGuardJon »
« Reply #35 on: September 12, 2011, 09:18:44 PM »
We agree regarding having a tick box to share your location, that is something that will be in future versions.
« Reply #36 on: September 13, 2011, 03:02:38 AM »
Nice to hear, but in this case I would prefer, that the displayed position is generated by using the degrees plus the first number behind the decimal point. Or even better: Insert second fields for geo-coordinates named "Location to Share". In this way every user is able to determinate how accurate the position shown on the map would be for his box/station.
Speaking for myself: I would have a problem to see my location generated by the ##.####N by ##.####E coordinates, which are accurate to a few meters. But I wouldn't have any problems with sharing my position with an accuracy of ##.#(#)N by ##.#(#)E, which would place my "real" location in a circle with a diameter of approximately 5NM(1-2NM).
