Photo Data anomaly
Started by tommyg, September 26, 2011, 05:27:44 PM
tommyg
Picked up GLF5 01 USCG  (code AE10C1) all details correct in My Flights and log but the photo was of Hungarian Aerobatic display team and the aircraft type (on the photo) said C17 Globemaster!!! Never seen  anything like this before. I had downloaded the new database before switching my RB on.
tommyg
Tommyg
Quote from: tommyg on September 26, 2011, 05:27:44 PM
tommyg
This is a long time and well known bug (and was discussed here several times before), which will hopefully be wiped out with the next software release.
Tommy
As Ingo states this is a well known long time bug.  The photo is picked from the serial/registration and cannot differentiate between the correct 01 and any other aircraft with a serial of 01.  The correct photographs are detailed, have a look at the aircraft with Database Explorer.  Unfortunatly this is ignored and the server stored photograph, as you have seen is used instead.
Hopefully this will be fully resolved in the next software version.
