Author Topic: Wimo power supply  (Read 2862 times)
Drazick
Wimo power supply
« on: October 03, 2011, 10:26:52 PM »
Hi, I have little doubt about the kind of adapter I need for WIMO Kit, they sent me a 12V / 200mA and I bought one of 12v/1.25A, Can you help me and inform me which is the most appropriate. Since in the website of Wimo say they need a 12V/1A power. thank you very much
Re: Wimo power supply
« Reply #1 on: October 04, 2011, 04:31:00 AM »
Depends on the preamp you are using. From my own experience with the wimo preamp I would like to say that you should use the 1,25A power supply. Because the 200mA Type may get a little hot.
Drazick
« Reply #2 on: October 04, 2011, 09:54:30 AM »
The model AS-1090 Pre-Amplifier.
« Reply #3 on: October 04, 2011, 07:44:32 PM »
Hi Drazick, I agree with Ingo, you need a heavier supply than 200mA, 1,000mA upwards shopuld be fine.   With a 200mA supply, it'll not only run a lot hotter (possibly even a fire risk if in unmonitored area such as a loft or roof space, but probably won't be able to power pre-amp optimally, and may not last very long before it cooks.
Drazick
« Reply #4 on: October 04, 2011, 09:06:06 PM »
Hello, thank you very much for your help, I do not understand why Wimo sent this power supply of 200mA, if the product is in danger. I will use the source of 1.25A.
