Logos
Started by RodBearden, October 15, 2011, 02:23:00 PM
Next stop companies house !
ACW367
Another Rebrand.  KGL
Kolavia has been relaunched as Kolavia Metrojet
The web address painted on the planes is for the main TUI travel agent site.  www.tui.ru
But as you can see the MetroJet livery is painted on the nose  http://www.airliners.net/search/photo.search?regsearch=EI-ETJ
Over to you to work the magic.
Rod,
Logo required :
PH-AXS (Using registration as flight ID)
Beech E90 c/n LW-297
Mode S : 484540
Operator : Leverco
http://www.leverco.nl/
Thanks, chaps.
I've done a Tui/Metrojet logo as seen on the aircraft, and I've called it KGL, assuming it is a direct replacement for Kolavia.
KGL - Tui / Metrojet
PH-AXS - BE9L of Leverco
vaca05
I'm having a hard time with the logos folder. I keep  getting a message that reads" Windows cannot open the folder. The Compressed (zipped) Folder 'C\Users\LP\Downloads\AllNewLogos_17-6-2012.zip is invalid." I downloaded the new outlines just fine.
Thanks for the help.
Larry
Hi Larry - that's strange. I just downloaded it myself again and it works fine for me.
Are you following the advice to "right-click the button and choose Save Link As... or Save Target As..."  ?
vaca05
Hey Rod
I'm still getting the same message. Don't know what I'm doing wrong. I would right click on the logos and click on the save link as. For some reason it will not open the file.
Larry
#548
HI Larry
Assuming the zip file is downloading OK on your computer. You should then find the file and double-click it to see the files it contains.
If you are using Windows 7, you should then see a button on the left of the bar above the list saying "Extract all files"  Click that to choose a destination folder, for example your RadarBox/Data/Logos folder, and it should work.
Please PM me if you're still having problems.
vaca05
Hi Rod
I finally got it to work. Thanks for the help.
Larry
Well done Larry :-)
After a long long time a Logo-Request from me:
DMROA (D-MROA) a BREZ of Oberlausitzer Flugsportclub e.V. (http://www.ul-ofc.de/15.html) I guess it'll be a H of a Job to shrink the Logo to the needed size.
Rod,
Just had the following on 'My Flights':
I-YLFC LJ40 c/n 45-2024
Mode S: 30034D
Operator : Air Four (Using flight ID of LSA402)
http://www.air4.com/it/
Ian,
The operator for I-YLFC was changed in the d/b to LSA on 28/5
Well, I've "interpreted" the German logo to fit our space. As to the LSA logo, which the FAA assigns to "Leader SRL" of Italy, there are at least four Leaders in Italy, so I've guessed.
D-MROA - BREZ of Oberlausitzer Flugsportclub e.V. in Bautzen
LSA - Leader Piattaforme Aeree
