Author Topic: Blanik L-13  (Read 3370 times)
anorak
Blanik L-13
« on: October 26, 2011, 09:21:14 PM »
I hope this is a miss code
Dave. Exmoor, North Devon.
Aerotower
Re: Blanik L-13
« Reply #1 on: October 26, 2011, 10:09:09 PM »
Yes, he should be with the code of Brazil, but also in your database, the aircraft type is incorrect.
PT-MVL - A330-302
Re: Blanik L-13
« Reply #2 on: October 27, 2011, 07:47:27 AM »
Hi Dave,
A47F78 decodes to N38928 and from the FAA, is the  Blanik L-13 as detailed.  The aircraft PT-MVL should be coded E47F78 so yes it is a miscode and the database is correct.  I will however mark A47F78 as miscoding and the code is in use by more than one aircraft.
Thanks for the heads up
anorak
Re: Blanik L-13
« Reply #3 on: October 27, 2011, 09:10:31 AM »
Ah well I suppose a glider at FL306/404KT was too much to expect.
Thanks,  Dave.
Note to self, get out more.
Aerotower
Re: Blanik L-13
« Reply #4 on: October 27, 2011, 10:37:00 PM »
Hi Dave,
Thanks Alan
