Traffic To/From Same Airport Filter
Started by Bigyun2000, March 21, 2008, 06:31:51 PM
Bigyun2000
Hi all
I am trying to set a filter so that when i goto Manchester a/c spotting, i can monitor all the a/c arriving and departing the airport.
I have managed to use EGCC in the Airport menu.  That seems fine.
in the quick filter area i set Route = EGCC*.  That seems fine but only shows a/c leaving Manchester.
How do i make the filter so that it works both ways?
A wish list addition could there be another selection in the filter drop down menu to the effect of AIRPORT.  This way all i would have to do is select AIRPORT = EGCC.
That functionality is already BUT it works on having all the aircraft flying in and out of the airport to have there routes listed in the database.
If the route is not the database the aircraft gets filtered out.
