"Help" facility / F1
Started by lwgxc08, November 08, 2011, 09:01:56 AM
lwgxc08
Does anyone else have this problem or have I installed incorrectly?
Neither the "F1" key nor navigation from the "HELP" menu bring up any help information.
Geoff
You should be able to find the help files if you go to start menu and find the AirNav Systems folder and then RadarBox. The issue has been noted before.
lwgxc08
I did work out how to get to the information thanks.  Just wanted to establish whether I had installed incorrectly.
If it is a known problem, I assume there will be a fix at some stage?
Geoff
