Keyboard Shortcuts
Started by lwgxc08, November 15, 2011, 02:46:24 PM
lwgxc08
I was wondering if anyone knew of any hidden/undocumented keyboard shortcuts for the ANRB software (4.03).
There are one or two things I would like to be able to have shortcuts for - one of them being to show/hide the interface window.
Geoff
#1
See http://www.airnavsystems.com/forum/index.php?topic=892
Quote from: lwgxc08 on November 15, 2011, 02:46:24 PMThere are one or two things I would like to be able to have shortcuts for - one of them being to show/hide the interface window.
Best I can do on that ALT-O  I  S
lwgxc08
Thanks Rod.   Useful Stuff.
The Alt+O+I+S is a decent compromise.
Geoff
Hi Geoff
That was Tarbat, but I can offer Ctrl-D to download the NASA image for the map area - very useful if you're in full-screen mode and can't get to the menus. Not exactly hidden, but useful anyway!
lwgxc08
Sorry Rod, Sorry Tarbat - think I got confused because the link pointed to your post Rod.  Not reading responses properley again ;-(
I wil give the Ctrl+D a go tonight.  That does sound very handy.
Thanks guys.
Geoff
Another useful shortcut is a quick way of going to different map layouts.  Save each map layout with a NUMBER in front of the name, and then right-clicking on the map and pressing S and a number quickly changes the map view.
Just in case it helps, here's a (full?) list of all the documented keyboard shortcuts.
bearcat
I guess this may not be documented but you can use the undrescored letters on the menu bar and in the dropdown boxes. For example ALT+O opens the tools menu and keeping ALT pressed use the N key to switch from My Flights to Network. To switch back to MY Flights ALT+O and then Y. You have to be quick as the tools menu closes quickly.
Hope this helps
