Started by orkney, November 26, 2011, 04:40:34 PM
0 Members and 14 Guests are viewing this topic.
Ingo,
05075F unknown to me
35AB28 unknown to me
3C4B16 decodes to D-ABXV nothing known to me
3C4D6E decodes to D-ACKN nothing known to me
3C5460 unknown to me
3C5CA7 decodes to D-AGEG B733 stored for part out at Kemble
3C6596 decodes to D-AILV nothing known to me
3C7D8C decodes to D-AOLL nothing known to me
3E36F8 decodes to D-IMAA nothing known to me
3E443B decodes to D-IRAP nothing known to me
3E5176 decodes to D-IWAW nothing known to me
3E690F nothing known
4008DA decodes to G-TMRA which was broken up in Edinburgh 2009
400BED decodes to G-VSPN became DEXHV and w/o Trier as far as the info I have available
400FD8 decodes to G-NYLE R44 c/n 11407 but became SE-JPZ
420162 miscode/decoding error
4241CD VP-CSW, Dassault Falcon 7X c/n 143 on delivery
43E8F3 M-ABEG AT72 ATR ATR 72-202 going to Fly540 Angola
440016 unknown to me
45ACCA decodes to OY-KFJ, docoding error?
484CBB unknown to me
4A8030 unknown to me
4A8107 unknown to me
4CA210 miscode ID not known to me
4D04C7 NATO E3 frames being noted using different codes, reallocation maybe?
502C84 still nothing about this one
867FA0 decodes to JA3376 Piper PA32 Lance now N97CR
A3736C decodes to N321QG not assigned by FAA, probable intentionally miscoded airframe as you state
A57111 decodes to N45PJ not assigned by FAA, only previous holder of the registration is now ZS-ECO, P46T, c/n 4697031
Nothing on your mil tac codes, as expected
about D-EXHV Luftsportverein Rietberg e.V. has it in their fleet-list: http://www.lsvr.de/flotte.html (http://www.lsvr.de/dexhv.html ) and is available for charter.  And, Rietberg is abaout 130km WSW of Hannover, so it should be plausible, that it is their airframe that I have repeatingly with combination 400BED and flight id DEXHV.
#1247
I can only presume the damage was not as bad as first thought.  Please see http://aviation-safety.net/wikibase/wiki.php?id=22446 for accident report.
I presume the one you are picking up is the same frame as it is still using the hex of its former ID
There is also a picture of it here taken in 2011 http://www.abpic.co.uk/search.php?q=D-EXHV&u=reg
Further info you may understand http://www.forum.flightxpress.net/index.php?page=Thread&threadID=11721
Now in the d/b as a miscode
flygfantast
4AB328 SE-LYH Saab 91D Safir, c/n 91470-1327, Private Owner
4AB4C6 SE-MFF Saab 2000, c/n 2000-038, Golden Air (ex Carpatair YR-SBA)
Niklas
Cable: Ecoflex-10 (10m+1m)
X
#1250
Rare 6830EA landed sandpit after an absence of 18 months, I assume still no news your end as not in db...however UP-CJ002 Canadair Regional Jet CRJ100ER Sapsan c/n 7354 has been seen on the ground. Will confirm on departure.
X
Its the correct country of origin anyway X, so await hearing from you about its departure
YXUphoto
N377SC (F2TH) is using wrong code of A445F5 (comes up as N3747A which is not able to fly at 30,000ft as seen)
Thanks Mark,
N377SC is allocated A44F5F, the other one, A445F5 is a powered parachute.  Is in the d/b under its own right and now also for the misscode
X
#1254
At a constant 800 nearby so knowing my luck probably a Bell using old Canadian hex!
* C05FE8                                                              2012/02/13 19:28:45
X
X
Lucky or what!!!!
its N450PZ Bell 412EP,c/n 36570, Bell Helicopter textron, squitting its old hex
X
Out of Washington State, new Boeing?
71C244
X
X
Quote from: Runway 31 on February 13, 2012, 05:57:27 PM
X
Lucky or what!!!!
So probably A6-??? by now so out with the goggles again!
X
X
71C244 HL8244, Boeing 737-8Q8, 38826/3984, Korean Air
Judwin45
477FF1 noted over SW England at 0800. Visually looked like C17 but picture and description did not seem right. It could be my dodgy recognition.
Keith, Somerset
Keith
5 miles south of EGDY
