Started by orkney, November 26, 2011, 04:40:34 PM
0 Members and 63 Guests are viewing this topic.
X
UP-CJ002 Canadair is currently in hangar (99% sure its 6830EA from its arrival time) but do you have a code for UP-CJ001 which was in last year while I was in MOW.
For info, 5A-UAA and B are back flying again after storage here for several months.
X
YXUphoto
C05519 translates as C-GGFW, but a/c is Rand-Robinson KR-2, which can not fly at 20,000ft as seen.  Must be a miscode.
ACA1DF ... unassigned.  Probably miscode.
38259A...F-WWVI.  Probably Dassault Falcon test reg.
chewycanes
Morning Alan
43E910 Callsign MFASH M-FASH Dassault Falcon 900B (from Manx reg)
Brian
YXU
C05519 decodes to C-GGFW which as you state is a KR-2, the aircraft you picked up must be miscoding this hex so will marked as various in d/b
ACADF decodes to N913AQ which is unassigned by FAA, so as you state an unknown miscode
39259A F-WWVI as stated a Dassault Falcon Test Registration
Morning X
I have all the info I need for UP-CJ001 and UP-CJ002 apart from their hexes.  Thanks for the update on both 5A- aircraft.
Morning Brian,
c/n 173 ex VP-BFH
Chris11
00996D ZS-JPS BE40   Raytheon Aircraft Company 400A   J P Smit Family Trust  RK-453
X
Sounds like a new PC21
4B14D3    c/s HB-HXB
X
X
New miscode?
A7C300 PR-SVR    C680
X
X
A7C300 decodes to N6EQ which is now PR-SVR, Cessna 680 Citation Sovereign, c/n 680-0204
4B14D3 HB-HXB, PC-21 c/n 129, look forward to you telling me is new details
X
#1286
4B14D3   HB-HXB PC21 c/n 129 will be 935 and use 896C11 but obviously still using CH hex (late delivery)
X
54901 - Jim
A12BE4 / N175BL - Liberty Mutual Insurance Co (correct spelling of Mutual)
Thanks, Alan!
KOSH - Oshkosh, Wisconsin USA
Morning, the unknowns from Sunday to Thursday:
1F69A7 (Russia, flight id's GAM7417 on two occasions, I presume more or less intentionally miscoded)
200000 (no country allocation, no flight id, received between 5400ft and 7000ft only)
3949FD (France, no flight id, 69 messages received)
3C4960 (Germany, no flight id, 9 messages received always at FL230, so I presume decoding error)
3C4B0A (Germany, no flight id, 28 messages between FL350 and FL250, seems to be a decoding error too)
3C546B (Germany, no flight id, 25 messages between FL350 and FL220, decoding error...)
3C5EF7 (Germany, no flight id, 25 messages between FL315 and FL218, decoding error...)
3C6656 (Germany, no flight id, 70 messages between FL266 and FL258,)
3C7D90 (Germany, no flight id, 42 messages between FL280 and 3905ft, strange usually if I get an airframe that low the message count is much higher...)
3DD3BF (Germany, no flight id, 214 messages between 770ft and 1040ft, seems to be a helicopter, possibly with registration D-HALB)
3E3C5C (Germany, no flight id, only 5 messages at FL230, more likely a decoding error)
400A16 (UK, flight id EXS788 on Feb 16th at 13:44 with only 10 messages received, seems to be a decoding error)
42427B (UK/Bermuda_9, flight id VPBBA, 274 messages no ADS-B on Feb 15th between 19:57 and 20:37, seems to be ex D-ACRE on delivery to YAMAL Airframe Details: CRJ2 Bombardier (Canadair) CL-600-2B19 CRJ-200LR CN: 7607 source: http://www.flightglobal.com/airspace/blogs/john_dyer/default.aspx )
440169 (Austria, no flight id, 48 messages received between FL359 and FL252)
44CFF6 (Belgium, no flight id, only 6 messages received between FL390 and FL347)
45AD11 (Denmark, no flight id, 41 messages between FL349 and FL350)
478316 (Norway, no flight id, only 7 messages at FL410)
478746 (Norway, no flight id, only 13 messages at FL360)
48404A (Netherlands, no flight id, 32 messages at FL330)
484446 (Netherlands, no flight id, 16 messages at FL350)
48ADA9 (Poland, no flight id, 2 messages at FL370)
491240 (Portugal, no flight id, 59 messages between FL344 and FL380)
49D256 (Czech Republic, no flight id, 15 messages between FL265 and FL210)
4AC820 (Sweden, no flight id, 81 messages between FL370 and FL369)
4BA8DE (Turkey, no flight id, 59 messages at FL370)
4CA8AB (Ireland, no flight id, only 16 messages between FL208 and FL360)
4FAB46 (no allocation, flight id's GAMVG07 62 messages at 600ft, GAMH41 167messages between 760ft and FL112, seems to be a miscoded GAM Helicopter)
506C0F (Slovenia, no flight id, only 6 messages between FL340 and FL370)
710030 (Saudi Arabia, no flight id, 33 messages at FL340)
76CCC3 (Singapore, no flight id, 25 messages between FL340 and FL269)
896098 (UAE, no flight id, 9 messages between FL295 and FL256)
C05655 (Canada, flight id DIXI29 two occasions 161 and 892 messages both times with ADS-B, Days: FEB 14th 12:31 to 15:12, FEB 16th 11:27 to 11:47)
That's all except the MILs in next post.
MIL stuff:
3E8CBE Germany MIL1 (flight id: LM11)
3E8F33 Germany MIL 1 (no flight id, 2 messages only)
3EA322 Germany MIL 1 (no flight id, 17 messages)
3EBC3E Germany MIL 1 (flight id's: none received, PANTER2, PIRAT)
3EBE41 Germany MIL 1 (flight id GAF910)
3F43AD Germany MIL 2 (flight id's: SHOCK2 on two occasion on two different days)
3F4688 Germany MIL 2 (flight id: WEED3)
3F4845 Germany MIL 2 (flight id's: GAF320, GAF320, TA44 on three different days)
3F4B2D Germany MIL 2 (no flight id, only 3 messages)
3F4C21 Germany MIL 2 (flight id's: TA12T, GAF727,TA61T,GAF914 on 3 different days)
3F4D0D Germany MIL 2 (no flight id, 27 messages)
3F596C Germany MIL 2 (no flight id, 3 messages only)
3F5D16 Germany MIL 2 (flight id: PACK)
3F60D0 Germany MIL 2 (flight id: SHOCK1)
3F62B3 Germany MIL 2 (no flight id, 18 messages)
3F6925 Germany MIL 2 (flight id: LK01A)
3F69FA Germany MIL 2 (flight id's: GAF120 on two different days)
3F82E0 Germany MIL 3 (no flight id, 31 messages)
3F8678 Germany MIL 3 (flight id: BOMBER1)
3F86B5 Germany MIL 3 (no flight id, 10 messages)
3F880A Germany MIL 3 (flight id's: GAFI70 on two different days)
3F8FB5 Germany MIL 3 (flight id: GAF914)
3F9653 Germany MIL 3 (flight id: SHOCK1)
3FA0A6 Germany MIL 3 (flight id: SHOCK1)
3FA76D Germany MIL 3 (flight id's: LM12, HAMMER)
3FBFE8 Germany MIL 3 (flight id's: GAF281, TA71, TA50 on two different days)
End of MIL list.
