Started by orkney, November 26, 2011, 04:40:34 PM
0 Members and 7 Guests are viewing this topic.
YXUphoto
7C3042 resolves to VH-JTG.  Was flying at around FL200, so don't think it is a Robinson R22 Beta.  More likely a Turboprop.
#1546
YXU,
Old database problem again, R22 VH-JTG was written off and is no longer in the current d/b.  There is no allocation against this registration on the Australian register at this time.  I can only presume this is a new aircraft which will appear on the register once it arrives in Australia.
Noted today at FL370 in Montreal area.
flygfantast
503DCA LY-NSC seems to miscoding 501DCA on one of its boxes.
Tracked 501DCA on flight NVD502 (242 msgs) and NVD503 (153 msgs). Also tracked it a couple of times last year.
Niklas
Cable: Ecoflex-10 (10m+1m)
Skyliner
VH-JTG c/n 145.687 Embraer 135 of JetGo on its delivery via Shannon
YXUphoto
A81685 decodes to N620CX.  Probably a miscode.
Its not assigned by FAA, so probably correct in your assumption
Judwin45
Mode s 601860 is showing as WHE06 EZ-A009 B737.
I think it should be a EH101 Helicopter, WHE06 is a Westland c/s.
Keith
5 miles south of EGDY
flygfantast
Not populating 511098, seems to be ES-AEB, the 2nd Embraer for Estonian Air.
See http://www.aviatime.com/estonian-air-to-get-its-second-embraer.html
Niklas
Hi Judwin,
As well as us, my d/b, Airframes and GAS have 601860 as EZ-A009, Boeing 737-7GL, c/n , 37235/2993, Turkmenistan Airlines since 2009.  It would therefore appear that EZ-A009 has been re-coded or the EH101 is miscoded.
It would certainly fit the sequence Niklas
Judwin45
Thanks Alan.
My guess is that the EH101 is miscoded. It has, I believe, UK serial ZR336. Final serial unknown.
Keith
Keith
#1558
Keith
ZR336 previously gave out 601862 as its hex and is c/n 50251
YXUphoto
A10C60 --> N167HB   Possible Miscode
AC973C --> N910FV   Possible Miscode
